Fuel was my 1st thought, but since it doesn't even attempt to fire using engine starter, I don't think that is the issue, at least not the primary one.
So I checked if I have 12V going to the coil through the relay I added and I do. I then popped the cap off, and everything inside looks new still (only got maybe 50 miles / 5 hours on the new rotor and cap).
I measured 270 ohm between the red and center wire as indicated by the yellow arrow in the pic below. Measured open between the center wire and the other outside wire and between the 2 outside wires.
The inside of the cap also looks like new with no signs of anything amiss.
And here is the coil itself. I'm getting about 0.5 ohm between the red and yellow, and open between either of those wires and the 2 black ground wires.
Not really sure what reading I should be getting, but it seems to me that my readings are off?
I guess the next step will be to put it all back together, pull one of the plugs, and see if I have spark when cranking the engine over. Need a helper for that test.
And with the plug out, might as well check compression on that one cylinder just for grins.
I did verify that the rotor is solid with no slop and it does turn when I crank the engine.
