Should i bother with this Rusty Dirty Hoe?
   / Should i bother with this Rusty Dirty Hoe? #21
I am thinking you should waste some fluid first by running tractor fluid through all cyl and put the return hose in a bucket to collect the old BH fluid.
Keep the tractor reservoir full when doing this.
It has its own pump and tank, not sure if the pump works yet either
   / Should i bother with this Rusty Dirty Hoe? #23
My mistake. Just look at the fluid and if looks like new, then you should be OK.
Started removing the cylinders, Pins don't look too bad
Was trying pull the rod out of the cylinder to remove oil & clean and its very difficult by hand, any suggestions ?
Also need to size these hoses/fittings. The fitting at top of cylinder measured 1/4" id on the hole. Hose is about 1/2" od
   / Should i bother with this Rusty Dirty Hoe? #25
Run the cylinder in and out by hand and you will get rid of 99% of the oil. Put in a cup of diesel and you can get the last little bit.
Aaro Z
Aaro Z
This was the issue, im a big guy but im not godzilla. could budge it a bit by twisting with the pin in or hitting with a hammer
   / Should i bother with this Rusty Dirty Hoe? #27
Use compressed air to extend and retract the cylinder but be careful it will go fast and probably throw a jet of oil
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
Chevrolet C8500 Flat Bed with a Moffet Kit (A53473)
Chevrolet C8500...
2430 (A51248)
2430 (A51248)
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
PumpJack Brand Pump Jack (A53473)
PumpJack Brand...
