I need an expedient ballast weight on 3PH
   / I need an expedient ballast weight on 3PH #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
So it looks like we might close on our new property in the next week or so. That means I'll have a bunch of my tools, steel, tool chests and four big heavy work benches to move out of a storage unit and into my new to me shop.
I currently have the L4330 with an FEL bucket and forks. Loading up at the storage unit will be by hand, using anyone I can find, including but not limited moving company people ($$$). However, at the home/shop end, I want to mainly use the tractor with the forks to take off, carry and move most of the above stuff.
Unfortunately, I don't have a bushhog or better yet, a box blade to counter balance the front end/fork loads. And since I don't have my tools or steel at the shop, I can't really make anything. All I have that's heavy and already at the shop is the FEL bucket. It's a quick disconnect/connect type bucket, flip two black levers and off it comes, same with putting on the Land Pride forks, pretty simple, but I don't know the actual name of the system.
Any way to install the bucket on the 3PH - safely? Any other ideas? I really really really don't want to have to handle those heavy benches or the 5 tons of steel again at the shop. But I don't want to use an unsafe and unbalanced tractor with forks either.
Help me Obi-TBN, you're my only hope!
   / I need an expedient ballast weight on 3PH #2
If I were you I would buy a set of 3pt forks.
They are cheap and you can pick up a pallet with any amount of things that weigh your desired counter weight amount.
Later on you will be surprised how much you can carry with forks on the front and back. :D
Good point, I should define what I mean by "expedient".
It means fairly cheap and easy. We're putting our money into the new property and I can't afford to buy any other implements right now, not for a month or so until we all the unknown unknowns out of the way.
Thanks,
   / I need an expedient ballast weight on 3PH #4
You could build a simple temporary counterweight from a barrel and a drawbar using basic hand /power tools. transport it empty then Fill it with rocks, gravel, dirt whatever at the new location. Once you get the tools unloaded you could make a more permanent counterweight from the same parts and a little bit of steel.
   / I need an expedient ballast weight on 3PH #5
Do you know someone that you can borrow a box blade and/or some suitcase weights to hang on it?
Brandon and rfgt, those are the two options I'm looking into right now.
One option, after reading one thread here and one person's experience with his unballasted FEL tractor during a parade, is I'm not using the forks without ballast of some sort.
Thanks,
   / I need an expedient ballast weight on 3PH #7
ftg, You mentioned heavy benches and 5 tons of steel ... but, just how much weight do you need to lift at one time? I don't know the figure, but there is "some amount of weight" that you can safely handle without ballast. I'd be curious to know if that figure is somewhere in print.
Egbert, my best guess is at least 500 lbs for one of my benches (3/4" thick steel table top). My big steel pile is at least that as well, bunch of 6'-12' length angles, channel, tubing, flats, etc. I'd rather take that off at once as well, pick it up, move it where it needs to go, let it down, done.
I got a 55 gallon barrel; I'll get the Cat 1 drawbar from tractor supply, my friend has a welder and we can cut steel with my air cutoff saw, slow, but it will get it done.
I don't have anybody I know that can drill 3/4" holes. What does Tractor Supply sell that already has a 3/4" hole already in it for my top link joint - that's cheap.
Thanks,
   / I need an expedient ballast weight on 3PH #9
Thanks,[/QUOTE]
Use a hole saw.. cheap from lowes or home depot. for the 3/4 hole. much easier and safer than a 3/4 bit anyway. you can use two pieces of angle steel. bolt those to the drawbar turned vertical inside of your 55 gallon barrel. By the way your front end loader connection system is called SSQA (Skid Steer Quick Attach)
James K0UA
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
1970 White 9000 Dump Truck (A51572)
1970 White 9000...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
7ft Adjustable Scrape Blade (A51573)
7ft Adjustable...
