How often do you run in 540E / ePTO?
   / How often do you run in 540E / ePTO? #11
That sounds like a really nice feature.
James K0UA
I run an MX8 with the 540E setting all the time. Nice, quiet, fuel saver.
It really is. I am super pleased with it. Great piece of technology!
Do you guys think you could run a PTO woodchipper with 540E? My gut tells me no because the PTO isn't running at a smooth, consistent rate with a woodchipper, but thought I would get some other opinions.
James K0UA
I need to do a little video of it sometime. It really makes mowing a lot more enjoyable. Less vibration, noise, etc.
   / How often do you run in 540E / ePTO? #14
I ONLY run the E-pto when knocking down the weeds in the pastures. Turning up hill with an MX 10 and mowing puts a good load on the engine. I usually dont run at 2400 when mowing this stuff either though. I'm working on building my fleet of attachments so thats really the only part I could comment on. I love the PRT but sometimes wish I could powershift in the midrange. Its a real bear trying to downshift going up hill when the going gets tougher.
I can see that as an issue, for sure. See, we don't really have hills here in TX, so I wouldn't know. :laughing:
   / How often do you run in 540E / ePTO? #16
Most of my implements are matched well to my tractor so I use the standard pto the most. Some things like smaller implements and spin spreaders are good candidates for the e pto though. About the chipper it would depend on the size of the branches and the feed rate whether you can use the epto or not, try it and see.
   / How often do you run in 540E / ePTO? #17
I use 540E most of the time on both 6' finish mower and 6' rotary cutter. The only time I have to throttle up is in very deep, thick brush. I was wondering how well my 5075M would pull an MX8 using 540E, but can't make the purchase to find out just yet. I get better fuel economy with the 5075M on 540E than I did with a Massey Ferguson 245 with the same rotary cutter.
   / How often do you run in 540E / ePTO? #18
Only clipping flat pasture post-grazing. 5085M
Thanks for the replies, everyone. This is good to get a variety of experiences / preferences.
   / How often do you run in 540E / ePTO? #20
You might want to run the chipper in epto to help lower the risk of damage. These tractor have enough power to really tear them up.
D.
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
MASSAGE CHAIR (A58216)
2011 Ford F150 XLT Pick Up (A55272)
2011 Ford F150 XLT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
