1 or 2 tractors (or more), what do you have
   / 1 or 2 tractors (or more), what do you have #11
At the moment, I'm running two tractors. The 1510 does all my grounds keeping, loader work, and raking, while the Major does all the heavy field work and baling. A third, sized between the two would make a nice addition. I'll put it on the wish list.
Joe
   / 1 or 2 tractors (or more), what do you have #12
I really like Soundguy's approach. The three point hitch isn't too bad until I try to hook up something heavy like a big old tiller, then I am cursing. I wish the industry had gone with the Farmall Fast Hitch system. As for tractors, got two fairly new tractors for heavy work and two old ones for light work, but still need a bigger one.
   / 1 or 2 tractors (or more), what do you have #13
11 total but 5 are always hooked up to something ready to go. Bare minimum to me would be 3, but to me tractors are like implements or tools. You need the right one for what you are doing.
   / 1 or 2 tractors (or more), what do you have #14
I only have 8 acres and have two tractors - a little Kubota that stays hooked to a pull behind finish mower for the yard, and a new Mx5100 for the road, tree work, etc... I love having the little one just for grass duty since it is needed weekly!
   / 1 or 2 tractors (or more), what do you have #15
NH TL100-A with FEL for BIG work.
Kubota B2710 with FEL for small work. 72" mmm for mowing under trees in pasture. 60" box blade for small dirt work.
JD Z820A for mowing 15 acres around house and out buildings at ranch.
MTD to pull fertilizer spreader around yard. Rick
   / 1 or 2 tractors (or more), what do you have #16
We have 2. My wife's is for cleaning stalls, dragging the arena and moving hay bales. Mine is for mowing or tilling.
   / 1 or 2 tractors (or more), what do you have #17
Nice assignment of duties.
   / 1 or 2 tractors (or more), what do you have #19
We have a bunch that are not used right now...
I use my 1720 for mowing and light loader work...
The 8050 for bush hogging...
When were were farming 3 small cattle operations we did what Soundguy did and had 1 tractor for bailing, 1 for mowimg, 1 for raking, and two for hauling hay...
We don't have any more cows but still have the tractors...
Life is good...
   / 1 or 2 tractors (or more), what do you have #20
No tractor, sold it, got something better to use on our 80 acres. :D
Moved the pin hitch up, put on a receiver hitch.
Has the skid steer quick attach.
Can lift the front or rear off of the ground.
Can move a lot of dirt.
Can move a lot of brush.
Can mow a lot of brush.
Can pull trees.
Can push it's self out when motion impaired.
It is a compact telehandler: http://www.tractorbynet.com/forums/...t/160568-compact-telehandler.html#post3243370
Using the Gorilla Grapple:
Grappling fun - A Picture Thread.... - Page 7
Tree Puller:
http://www.tractorbynet.com/forums/attachments/277824-tree-puller.html#post3444397
2017 Ford F-150 Pickup Truck (A50323)
2017 Ford F-150...
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
