Insulating a metal building...options?
   / Insulating a metal building...options? #1
iowa
Hi.
I have a 70' x 40' x 16' (ceiling height) metal building. The 2"x6" studs are 8' on center. The floor is concrete.
I would like to insulate the building so I can heat it to about 60 degrees on a cold (10 degrees) Iowa winter day.
I have priced spray foam and it is higher than what I would like to pay.
Are there any other options available to me?
Would using foam board insulation work? I understand the material is the same as some spray foams.
Thanks.
   / Insulating a metal building...options? #2
I can't imagine foam board insulation would be comparable in performance to the spray foam.
One concern will be the inevitable air gap between the foam board and metal walls and the condensation that may lead too. The other concern is the spray will leave no voids but the foam boards will, because you can't fit them that tightly or bend them to fill any irregularities.
   / Insulating a metal building...options? #3
They make fiberglass insulation bats for insulating steel buildings. They are usually lined with plastic on 1 side.
I can't imagine foam board insulation would be comparable in performance to the spray foam..
I agree.
There is still the possibility of condensation behind the wooden wall studs that don't get sprayed with insulation. Spray foam insulation is probably the best method at this time but foam board would have to be better option than fiberglass bats--which some people use.
   / Insulating a metal building...options? #5
I agree.
You would be spraying the sides of the studs and the corner made by the stud side and metal, that should seal it fairly well but I agree, it won't be total. Where air cannot go, condensation is going to be very limited.
Maybe you could focus on insulating the ceiling first and see how the building heats after doing that. The ceiling is where the most heat is lost. Is the ceiling closed in, or is it open to the underside of the roof? Closing it in will reduce the air volume to heat and keep the warm air closer to you down below.
That was an option I posed to the spray foam companies that gave me quotes. They said they would not even do the work if that is how I wanted to proceed. They 'said' that I wouldn't be satisfied with the results.
The building does have a metal ceiling below the roof.
I've even wondered if I could somewhat heat the building with just a couple of forced air furnaces when I needed to heat it.
   / Insulating a metal building...options? #7
Well, the foam sprayers are generous with your money. :laughing: They may fear you would blame them if the building wasn't warm enough to suit you.
Exposed 16' metal walls are going to be chilly no doubt, but the ceiling is what traps whatever warmth you put in the building and would be the logical place to start if you want to spread out the costs over a couple of years. Is there a vapor barrier on the metal ceiling panels?
With a vapor barrier you could blow in cellulose yourself and get good results. You can rent the shredder/blower or it may be provided free from where you buy the cellulose. It's a two man job, one to work the hose and another to feed bales into the blower.
I'm sure with enough btu's, you could take the chill off a work area with forced air if that's all you need to do.
   / Insulating a metal building...options? #8
I've read that spray foam gives off toxic fumes in enclosed areas and needs to be sealed or well ventilated. Maybe the new stuff is better than the old. I like fiberglass bats and a second interior wall. Figure out you vapor barrier situation to avoid condensation inside the wall area.
   / Insulating a metal building...options? #9
so can you put up board insulation across the bottom of the trusses before the walls are sprayed in? Or is it worth the additional cost to spray everything?
   / Insulating a metal building...options? #10
After you get it " sprayed" do some research on infrared heating, with those tall ceilings most of your heat will be over your head.
Infared is fueled by lp or nat gas in long tubes and warms objects not the surrounding air, just like the sun does.
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2842 (A54756)
2842 (A54756)
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55315)
Koyker Loader...
