Reverse Backhoe bucket
   / Reverse Backhoe bucket #1
Desert Bred
Goodyear AZ
1998 CKC TS 254 (Fei Dong 295T1)
Anyone here done that before? I have a koyker backhoe that I'd like to flip the bucket on -OR- get shorter clamp on forks
to
help me get under the root ball with a backhoe because i don't yet have a FEL.. seems like forks on a bh bucket could be very useful in transplanting trees rather than FEL forks.. been searching and searching for alternative style buckets and found a ripper.. but still nothing.. any ideas out there?
   / Reverse Backhoe bucket #2
I seem to recall someone doing that. One important note, the bucket cylinder has more power curling in the normal direction than it will uncurling. This may be important with the bucket on backwards and diging that way. This has to do with which side the rod is on giving the fluid less surface area to push against.
   / Reverse Backhoe bucket #3
Very true, but then if that power was needed one could always reverse the bucket cylinder as part of the conversion.
   / Reverse Backhoe bucket #4
How would you do that?
   / Reverse Backhoe bucket #5
Good point.
   / Reverse Backhoe bucket #7
Just rotate the cylinder 180 degrees so the rod is towards the backhoe rather than away from it. You will need to extend the two hydraulic lines, certainly the one closest to the backhoe which is now going to be closest to the bucket. The other one should be in a similar location andyou may be able to adjust the existing line.
   / Reverse Backhoe bucket #8
If this idea catches on, there may come a day when a big selling point on backhoes is a reversable arm and bucket.
'face mode'
btw- i just started welding. where do you guys go to get your metal from i.e to make buckets/attachments?
   / Reverse Backhoe bucket #10
2016 International WorkStar 7400 Cylinder Pallet Flatbed Truck (A55852)
2016 International...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
PALLET OF (2) ELECTRIC CONDUIT BENDERS (A55745)
PALLET OF (2)...
