Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album)
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #1
Daver1963
Idlewild, Tn
Kubota L2800DT w/LA524 FEL, Cub Cadet XT1
A little tractor lean-to project with a photo album from Facebook.
If you're not a Facebooker I'll post a few pictures if you want to see them.
I needed something to park my tractor under so I could get my truck in the carport come winter time.
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #2
Don't do no bookface, already got more than enough foolishness in my life and got things need accomplishing.
That bookface just another way for people don't accomplish squat to waste time and spend money they ain't got. Foolishness is for children.
I guess some real pictures are in order. The pictures are titled day 1-4, but I didn't build this in four straight days. I had to take two days off after digging the post holes and setting the posts to let my hands recover. With the help of my sweet wife it took a week and without her I'd still be building.
Before
The Plan
Laying it out
Wife moving the tractor
Posts set and waiting for concrete to cure
Using string and a line level to establish a reference height
Line level from Lowes 2/$3
Putting wall studs together
Moving the stud wall
Getting it into position
Stud wall up
Getting the rafters up
Papa Gene supervising
Getting the roofing on. I used two translucent panels
in the middle to provide ambient light inside the lean-to
Almost done with the roof
Roof finished
Side panels on
After. The tractor at home
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #4
Nice work, looks good.
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #5
Looks like the FB page is not linked correctly it takes you to pictues page but did not show up with the pics you posted, maybe a project specific page. I prefer Photobucket for this as I can lock folders and keep pics hidden and or they have better space/ projects with ability to move photos into a time line a bit better I think.
Mark
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #6
How big are those rafters? Do you get any snow at all?
The rafters are 2 X 4's. Here in Northwest Tennessee we haven't been getting vast amounts of snow in the last few years. However, the Farmers Almanac says it is suppose to be colder and snowier than normal. I'll probably be scraping snow off all winter!
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #8
It looks good Dave. But I think I would have run the tin the other way. Or is that the way it will drain? And with that tree so close, you will need to sweep the leaves off. We had some of those clear panels on a shed. They held up for 15 or 20 years. As long as a limb don't fall on them.
Larro
   / Tractor Lean-To Project (and checking to see if you can link a Facebook Photo Album) #9
good job.
That is not the way the tin will drain, but I did it that way after getting the rafters up and realizing that there was no way to support where the two tin pieces joined together. I couldn't think of an easy way to join the edges. I thought about caulk and about drilling and riveting.
Deere 310L (A53317)
Deere 310L (A53317)
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Deere 310SK (A57148)
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2014 Ford F-250 Ext. Cab Service Truck (A59230)
2014 Ford F-250...
