Looking at a Massey, pros and cons of 3 cylinder?
   / Looking at a Massey, pros and cons of 3 cylinder?
   / Looking at a Massey, pros and cons of 3 cylinder? #42
The overall fit and finish seemed less than the my current tractor (JD 5425). ..
The 5425s are nice tractors, I have one. I like it, only has about 700 hours so far. The loader is a little slow but it is an excellent tractor. Little problem with the joystick once, but other than that, it has been a dream. Sorry to hear of the comments about the once proud NH/Ford line.
   / Looking at a Massey, pros and cons of 3 cylinder? #43
The waiting is harder on my wife I think... I keep watching MF 5600 tractor videos, looking for any piece of information online, and going over the brochure time and time again. It drives her nuts.
Really like the 5425. My issue is local dealer support more than the tractor. I was set to buy a 5100M from another dealer, but for a couple thousand less I'm getting the MF 5609. I'm really enthused about the Dyna 4 transmission (wife can drive it in autodrive) and the combined flow for the hydraulics. Great loader tractor.
   / Looking at a Massey, pros and cons of 3 cylinder? #44
I am really glad to see excitement about Massey's new tractors. And of the AGCO engine. They have such a proud history.
Just wanted to thank everyone for the help. I pulled the trigger tonight. You can see my post in the Massey forum :)
   / Looking at a Massey, pros and cons of 3 cylinder? #46
Congratulations are in order!!!! I will check it out.
   / Looking at a Massey, pros and cons of 3 cylinder? #47
I own a MF 4610 for about 8 months now. I bought it from a JD dealer with 96hours on it. In some ways it has been a great tractor, but it is not perfect.
Here is a list of pros and cons from about 150 hours of use, mainly with loader work or round baling:
PROS
* Controls and levers positioned very nicely
* Hydraulics are fast, especially on the loader
* Tractor is about right for hp to weight ratio
* No emissions maintenance
* Cooling system is more than adequate to keep the engine cool in hot weather under full load
* Heater works very well
*Nice progression of speed thru all the gears.
*Frame, chassis, 3 point, built heavy and strong.
CONS
* 3 cylinder engine has an awful lot of vibration and is noisy. Depending on load (if you lug the engine down some), and at just the right rpms, everything in the whole cab vibrates to such an extent that I have spent hours searching for ways to tighten things and to find ways to minimize noise, to no avail.
* Cab is very noisy, see above
* Air conditioning is weak, cannot keep up in normal conditions
* Engine has very low power until it is fully warmed up. I think this is controlled on purpose by the engine computer.
* Engine is made in China. While Agco bought Sisu in Finland, and Sisu designed this engine and it bears the Sisu name - Agco built a new factory in China just to build these engines for the 4600 series. So the tractor is made by Iseki in Japan, but the engine is made in China with the Sisu name :mad:
* Really dislike the transmission. Granted, I put thousands of hours on tractors with hydro transmissions, and my last one was an advanced 6 speed hydro (so I am biased) - this transmission is NOT user friendly. 1. It is VERY hard to shift. When speeding up or down I can almost never get it into 4th on the first try. 5th is better, 6th always feels like it only goes in halfway, and I have had it pop out. 2. The power shuttle is a great idea but is not smooth. Especially if you do anything with the clutch. If you are in an open space and just shuttle it isn't bad. But if you ease into a spot, press the clutch, shuttle the lever, and then let the clutch out - there is a delay where nothing happens and then it engages from 0% to 100% in an instant, causing violent jerks. 3. The clutch has no sweet spot. It is all electronic and although it moves quite a distance, it goes from 0% to 100% in about 1/2" travel. Also, if you try to feather it all the tractor makes you deaf with an ear splitting warning beep and it says you are riding the clutch pedal. You almost cannot back up to a piece of equipment without it doing this to you. 4. All of the problems with the transmission described above are worse in cold weather.
* Rear hydraulics - 1.They do not have float function on the levers. Dealer said it wasn't available when I bought mine, but is now. 2.The rear couplers are not push/pull connect. They have no break away either. If your implement unhooks you will damage something. You also CANNOT disconnect or connect anything under even a slight pressure. Having no float on the levers makes it worse. You must stop tractor and jiggle lever to depressurize so you can unhook.
* Front headlight shrouds are cheap plastic and fell off. Warranty replaced them but dealer made me pay shipping. New ones they sent are somewhat improved design. Still cheap plastic.
* Fuel tank is WAY too small. 24 gallons on a 90 horse tractor? get real. I can kill the tank in about 8 or 9 hours with my round baler in normal load conditions. There are actually two tanks with one fill point and the connector between is small. That means you fill real slow and wait for fuel to siphon to other tank and then top it off again, repeat about 6 times to get tank full.
* Too many error codes. Engine has given me a number of different error codes, mainly with fuel system. Had dealer here with computers to try to resolve. Fiddled around half a day to diagnose. Had to pay next day air charges on a part from Agco in the middle of hay season. Got problems resolved that time but ever since tractor has noticeably less torque. Plus warranty paid for only 30 minutes of the service guy's time, and no travel charges. (my dealer is not real close.) Now just today it threw another error code about fuel system, different one this time. Still unresolved.
* Starts hard in cold weather. The tractor has no block heater and no glow plugs. It has a lame air intake heater which is mostly worthless. If it gets below 20 degrees F you will have some trouble getting it running. It has always started but sometimes took multiple attempts.
So there you have it. That's where I'm at. I don't know how all of this compares to JD, Kubota, or NH. I think the others may not be any better if you compare $$ and hp. Kubota is known to have undersized cooling systems and their engines always overheat (personal experience), NH is known to have poor ground speeds and poor control layouts, JD also is known to have some issues, especially in the E series, and is usually more $$.
Would I buy Massey again, probably, but I will never buy a 3 cylinder this size again. There is just no way a 3 cylinder can run as quiet and smooth as a 4, 5, or 6. My choice would be the 5600 series with the 4 cylinder Sisu actually made in Finland with the Dyna 4 transmission. Totally European tractor, not Japan and China. Way better cab. If you can afford it, definitely step up...
PA farmer
2014 Dodge Charger Sedan (A55758)
2014 Dodge Charger...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
1993 PETERBILT 362 SLEEPER (A54607)
1993 PETERBILT 362...
