Block Heater for 3016 Diesel Shuttle
   / Block Heater for 3016 Diesel Shuttle #1
rmay66
Abingdon va
Mahindra 3016 Shuttle
Anyone have knowledge or experience installing a block heater for a Mahindra 3016 Diesel Shuttle? Mahindra wants roughly $300 for theirs...is there a 3rd party product that is cheaper and works efficiently?
   / Block Heater for 3016 Diesel Shuttle #2
Hi rmay66, I couldn't help but respond to your post since you are in my neck of the woods. Just curious, is your 3016 stubborn in cold weather?
   / Block Heater for 3016 Diesel Shuttle #3
Before paying $300, I'd be down at the local thrift store, picking up a cheap electric blanket; which just might be a 3rd party product. :) It would work, wouldn't it?
   / Block Heater for 3016 Diesel Shuttle #4
A universal in line lower hose heater will work just as well for under $50 and it's available at auto parts stores. Just need to buy one that fits the inside diameter of the lower radiator hose.
   / Block Heater for 3016 Diesel Shuttle #5
I priced a block heater for my 3016. Mahindra quoted about $195. I guess I will take George2615 tip and find an inline hose heater. It dropped to -25.8 last night. Pretty hard to start a diesel under those conditions.
   / Block Heater for 3016 Diesel Shuttle #6
A Risk Management Perspective
The cost of replacing an engine ($thousands)
Divided by the probability (short-term severity of -25 degrees f)
=Risk (high).
Mitigation: So, at a bare minimum, running the engine for 12 hours a day (4 hours on & 4 hours off intervals) in the interim, would cost less than replacing the engine. This is what we did with our vehicles on the Korean Peninsula back in the early 80s.
Wouldn't a "Frost King" do the same thing on a lower radiator hose; keep the engine somewhere near the starting temp.
Frost King 6 ft. Electric Water Pipe Heat Cable-HC6 at The Home Depot
   / Block Heater for 3016 Diesel Shuttle #7
Some options at > Kat's
A buddy of mine in California mentioned the magnetic heater stuck to the oil pan worked well for him
   / Block Heater for 3016 Diesel Shuttle #8
I can help you out here. What kind of block heater was mahindra's quote for ? Screw into the block type or freeze plug type? If you have an available freeze plug.... use it!!!! They are not hard to install, but not easy in any way in cold weather. Freeze plug type heaters heat TVs coolant closest to the engines cylinder walls and combustion chambers. All auto parts stores are able to get freeze plug type or radiator hose type heating elements! 25$ to 75$ for either type. If you are going to have trouble with the install a friend who is a mechanic will be of great help. Here is a video of a radiator hose type heater if for some reason a freeze plug type will not work. Radiator hose types work well but less effienciently that something mounted inside the block. In either case get the highest watt heater you can as that will be hotter and have a larger element! Oriellys has ever start brand which I highly suggest.
   / Block Heater for 3016 Diesel Shuttle #9
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
12ft. Flatbed Truck Body (A59230)
12ft. Flatbed...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
