Ballast Photos
   / Ballast Photos #1
cartod
Northern, West Virginia
JD 4066, 1023
Post a photo of your ballast. Im using a box blade with suitcase weights, and when I need to go big I put a slice of a millstone on.
   / Ballast Photos #2
BX with a custom weight bracket and 5 weights.
L4240 with a Woods HBL84. I am going to make a 1000-1200lbs counterweight someday for it.
   / Ballast Photos #3
Here is mine:
   / Ballast Photos #4
Another box blade/suitcase weight combo.
Joe
   / Ballast Photos #5
For my JD 790, I use a JD ballast box I got of CL, filled to 620 lbs. of scrap iron, including the RR rail runners & receiver tube bolted to the bottom. Chainsaw sleeve & tool holders added to the outside. ~~ grnspot
   / Ballast Photos #6
I use my back blade. Its a Land Pride 3596 - plenty heavy and doesn't extend out back too far.View attachment 342521
   / Ballast Photos #7
I use these old scrapped actuator end caps - my son welded couple of brackets for me and milled slots in the smaller end caps in the bottom to make it a nice package. I use it most of the summer months. Great for moving trailers and boats around, great visibility to the ball. Loader work made easy and with a small utility trailer, the perfect combination.IMG_0806.jpg
   / Ballast Photos #8
I use these old scrapped actuator end caps - my son welded couple of brackets for me and milled slots in the smaller end caps in the bottom to make it a nice package. I use it most of the summer months. Great for moving trailers and boats around, great visibility to the ball. Loader work made easy and with a small utility trailer, the perfect combination.View attachment 342591
Whoa! That is some serious metal!
   / Ballast Photos #10
SHOP FAN (A55745)
SHOP FAN (A55745)
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
MILLER THUNDERBOLT XL (A55745)
MILLER THUNDERBOLT...
2014 Mack CXU613 Truck, VIN # 1M1AW02Y6EM040637 (A54865)
2014 Mack CXU613...
MULTIQUIP WHISPERWATT MQ POWER 25 GENERATOR (A52706)
MULTIQUIP...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
