CHARGING PROBLEM FORD 5610
   / CHARGING PROBLEM FORD 5610 #1
Fraisier
Deleage Qc.
Ford 5610
LOOKINF FOR ELECTRICAL PLAN FOR A FORD 5610, 1985
   / CHARGING PROBLEM FORD 5610 #2
what kind of problem are you having 1985 model should have a motorola alternator number 8al2055f 12 volt 32amp
Ford 5610 1985, Motorola alternator and voltage regulator. These have been replaced. I do not get power feed to the regulator.
   / CHARGING PROBLEM FORD 5610 #4
can you get numbers off your parts or post pictures of them
   / CHARGING PROBLEM FORD 5610 #5
G'day IIRC you should have a charge light on the dash, does this light up when you turn the ign on?? If not then check globe as power need to travel through the globe to excite the alternator.
Jon
Jon
I was trying to find a plan to follow the wiring of the charging module. Even the book I bought and downloaded ( published by ford at the time) was not clear to me. To many models of tractor in the same book. 2500+ pages.
I finally ran a new wire between the alternator and the starter and everything works.
Thank you
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2017 Peterbilt 220 16FT Box Truck (A51692)
2017 Peterbilt 220...
100' Roll of new 5/8"/16mm Crane Cable  (A52384)
100' Roll of new...
CAT 257D (A50123)
CAT 257D (A50123)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
