In cab fire extinguisher mount
   / In cab fire extinguisher mount #11
The Velcro is a possibility, but I would like something that looks good as well. I also don't want to be in a situation where I need the extinguisher and I need to use both hands to pry it off of the floor. It is a crew cab truck with carpet over the tunnel. I was recently at a car show and I saw a Porsche 911 with a fire extinguisher mounted in front of the passenger seat with the mount bolted to the seat rails. I have been looking for something similar but have struggled to find something that may work in a truck. I am also concerned about limiting my seat travel if I mount anything directly to the seat rails as well as kicking the thing every time I am getting in or out of the truck. Here is an example of what I have seen on some other vehicles.
Fire Extinguisher and Mount Package - Power Seats-Rennline, Inc.
Buy a fire extinguisher with a mount...All you have to do is un-clip the straps to release it, the mounting hardware is irrelevant.. Had one of those in my Chevelle.
   / In cab fire extinguisher mount #12
Sew a bag that fits the extinguisher with material the same color as your upholstery and add straps to attach it to the seat frame. Fas-tech fasteners like on backpacks or quality mountain gear.
   / In cab fire extinguisher mount #13
I actually never thought about this until my buddys wreck. I saw the truck first hand at the junk yard afterwards. I was amazed at the internal damage from the items I mentioned.
In all seriousness its unlikely to kill you but even a coffee mug or a can of unopened soda could in such a accident.
Chris
As an EMT years ago I responded to the scene of an S10 Blazer vs telephone pole. Drunk driver and passenger, car rolled several times before coming to rest in a front yard of a home. Rear compartment was full of big heavy tools like ratcheting comealongs . Neither guy survived as I remember.
Of course I drive around in my truck with heavy stuff in the bed and trailer, and no bulkhead behind me... :eek:
   / In cab fire extinguisher mount #14
I have been looking to install a fire extinguisher inside the cab and I have a few different criteria that I want to fire extinguisher mount to fulfill.
What type of extinguisher - Dry Chem or Halotron? Halotron is more expensive but recommended for vehicles.
   / In cab fire extinguisher mount #15
I recommend a six pack of cheap beer.
I was driving a car one day and the owner had taken the air filter off. The car backfired through the carb and caught fire. I called for a fire truck but before they got there I had located a six pack in the rear floor board and shook one up and popped a top and the fire was out before the firetruck got there. After a few minutes the thing started right up and I drove it straight to the jail.
   / In cab fire extinguisher mount #16
I saw a car at the drag strip backfire through the carb (something Chevys are famous for) when he went to do a burnout. It had a cowl hood on it and you could see the fire. The car was a pretty fast car, it had a roll cage and a 6 point harness. The guy working the burnout box did not know what was going on and the driver was trying to get out out the car. A guy walked up with a big lemonade and threw it under the cowl hood and put the fire out. The guy started the car back up and ran it.
   / In cab fire extinguisher mount #17
Lemonade would certainly work. :thumbsup:
I think the beer worked good because of the foam.
   / In cab fire extinguisher mount #19
Don't some fire extinguishers shoot foam?
I think some do. That was the one and onlt time I've ever needed a fire extinguisher around a vehicle.
I did see one burned to the ground on the side of I35 the other day. Fire trucks still there but it was a crispy critter. Caused a big traffic back up too.
I recently bought a 2.5 lb ABC extinguisher with a mounting bracket included. It would be nice to figure out a way to attach a mount using some of the existing hardware and attach the fire extinguisher bracket to that. I have been throwing around a few ideas with a friend of mine who is a fabricator. Hopefully I can articulate what I am after and let him take care of all the welding. If the first try doesn't look like a pile of scrap, I will make sure to post pictures. Thanks for the help so far. I think I will try and stay away from the beer and lemonade method so I have something to drink when I get home.
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
2011 John Deere Tractor (A55973)
2011 John Deere...
Wooden Swing Bench (A55853)
Wooden Swing Bench...
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
2018 MERTZ MANUFACTURING 2500HP QUINTUPLEX FRAC PUMP (A55745)
2018 MERTZ...
Wooden Rocking Chair (A55853)
Wooden Rocking...
