Need help please?
   / Need help please? #1
Aaron hoedown
Massy 2310 TLB
WHat is the name of the part that the joystick attaches to, to operate the loader? The valve body part? Is it a fel?
I have a 2310 and the hydraulic fluid is leaking out pretty bad! Can I rebuild it (the part for which I don't know it's name), or do I need a new one?
   / Need help please?
Sunday bump!!!
What is it called a spool? Loader control? Valve body?
Anybody?
   / Need help please? #3
Control valve is what I call it. Valve, control, spool valve, hydraulic control, hydraulic valve. I'm sure there's more.
It can be rebuilt. There's a tag for identification on it you will need the numbers on it to get the right spool seals.
   / Need help please?
Control valve is what I call it. Valve, control, spool valve, hydraulic control, hydraulic valve. I'm sure there's more. It can be rebuilt. There's a tag for identification on it you will need the numbers on it to get the right spool seals.
thank you very much MFRED.
   / Need help please? #5
Aaron, how'd you make out? Here's a page from the Service Manual; they called it a control valve assembly. Sorry the photo quality isn't great-- if you need a blow-up, just let me know.
irvingj
   / Need help please?
Aaron, how'd you make out? Here's a page from the Service Manual; they called it a control valve assembly. Sorry the photo quality isn't great-- if you need a blow-up, just let me know. irvingj <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=347291"/>
Thanks for the diagram. It's going to use that in the future. I phoned the stealership today, they want $1200 fn' dollars for one!!!!:(
   / Need help please? #7
Ouch!!!!!!!!!!!!!!!
   / Need help please? #8
Some control valves can be rebuilt, but that is to only replace o-rings for the spool shafts.
If the spool shaft and or bore is worn, there is no solution for that. They are a precision fit.
A new control valve is called for such as these joystick valves.
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
2 SPOOL 14 GPM PRINCE LVR JOYSTICK LOADER VALVE
You should be able to simply remove and replace using whatever fittings you need.
   / Need help please? #9
Well, Aaron, best of luck, and please keep us all posted as your progress. If you could get some pics of the leaking, perhaps someone here can give you more accurate advice, other than simply replacing the whole valve.... irvingj
   / Need help please?
Thanks for the support guys. Those links to the two spool valves will come in handy.
The update isn't so good. I reinstalled the joystick unit because we had a snow storm coming. Any way after I installed it I couldn't get the backhoe to operate unless I also was operating the bucket, so I locked the hoe into travel mode.
After the storm passed I used the bucket to move the snow and then parked it. Since then I've started it and now the bucket won't operate either?! The machine is not low on fluid and will still move under her own power, although the power steering is really stiff. :(
Does anybody have any ideas on what my most recent 2310 issue might be?:(
I'm going to drain the unit and check the screen. If it's full of metal again I'm going to be very sad/angry!?:(
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER REEFER (A52576)
2020 HYUNDAI...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
