Who's got the best grease setup? What do you use?
   / Who's got the best grease setup? What do you use? #1
WaxMan
USA CT
Kubota Grand L 3240 cab BH 92 backhoe
Since greasing the tractor is one of the most important things a tractor owner can do, Just wondering what others are doing for greasing? I just have a "one hand" run of the mill grease gun, I hate it, I hate doing it, I hate the mess. I'm thinking of getting an electric one and mounting it somewhere on the tractor or backhoe to make it easier to grease and remember to grease. What do you use? and how do you like it? And are you fatefully greasing every ten hours of use?
   / Who's got the best grease setup? What do you use? #2
I use a pistol grip style grease gun and yes I grease daily. I am a fulltime driver. I have not got an electric grease gun , but in a commercial situation it would "walk" quickly.
Tip : if you have trouble seeing a grease nipple try to spray paint in white or yellow (shows well in poor light), espesially if it is a pto shaft, and painted black as the fashion/style seems to be these days.
   / Who's got the best grease setup? What do you use? #3
I use a Lincoln pneumatic grease gun (1162 - about $80 or less). Liked it so much that I bought two more and run different grease in the three guns.
Can't beat the ease but you do have to have an air supply. In the field I have a 20 gal. compressed air holding tank that is used to power the gun. The air easily lasts until the opportunity to refill it.
10 hours greasing? Absolutely. With the backhoe it is usually more often. The quality of the grease is important, too. My favorite is TRC 800 but Lucas and AMSOIL also have quality grease.
For disc bearings and other implement bearings exposed to dirt and dust a cheaper brand grease is used and more is pumped in to displace the gunk.
Note: Electric guns are heavy and inevitably the battery will go dead when you need it the most. And batteries are very expensive when it finally dies completely. Compare prices.
Looks good
Lincoln 1162 Air Operated Grease Gun : Amazon.com : Automotive
Does it take a long time once changing grease tubes before it starts coming out again like the hand pump one?
   / Who's got the best grease setup? What do you use? #5
We buy Lucas by the case lot but use a mechanical grease gun and try to grease every ten hours
   / Who's got the best grease setup? What do you use? #6
   / Who's got the best grease setup? What do you use? #7
I grease mine every ten hours or sometimes sooner. Biggest issue is when the implements or FEL get a little wear and become hard to grease. Even the pneumatics can be messy and the one I have will not give enough pressure in some instances. So I prefer to use a full size pistol grip gun with flex hose, but it took me a while to find one that had enough pressure. I hate to say it here, but the one I found is a John Deere model TY26689. It is assembled(?) in the U.S., has a selector lever for either volume or pressure, is rated at 7500psi, and at $36 list price is hard to beat. I have yet to find a plugged zerk that it would not put grease into.
   / Who's got the best grease setup? What do you use? #8
This is what I have and use Milwaukee 2446-21XC M12 12-Volt Cordless Grease Gun - Amazon.com I am not promoting Amazon its just that they have pictures and reviews, you can buy them cheaper if you shop around.
I have arthritis in my hands and was having trouble with the pistol grip and lever pump grease guns. This Milwaukee M12 grease gun puts out 5000 psi, has a 36" whip with a holder to keep it clean and an extended run 12 volt Li-ion battery. If you need more power they now have out an M18 that put out 8000 psi.
This is a good grease gun and really works well for me, I have no experience with the other battery operated grease guns and I am sure they are all fine guns and work well for others. The thing I like about the Milwaukee that the batteries can be used on other Milwaukee tools, drills, saws and etc.
   / Who's got the best grease setup? What do you use? #9
Ta Mate. I've got some JD yellow paint in the shop... looks like another wee job to add to the list! :thumbsup:
   / Who's got the best grease setup? What do you use? #10
I use an air powered gun I got at Home Depot with "red" grease. One other thing I do is change out the zerks when they become a bit plugged. You can get them thru Amazon for a lot cheaper than at the dealer. If memory serves the 8mm is the most popular but occasionally I have found a SAE gets into the mix.
2013 GREAT DANE 53FT REEFER TRAILER (A59905)
2013 GREAT DANE...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
