I am looking at this air compressor at Tractor Supply - Ingersol 2-stage
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #1
jimgerken
Minnesota
John Deere 3720
Ingersoll Rand | TS4N5 Two-Stage Reciprocating Compressor
I need to replace a 5 hp single stage Puma, 60 gallon. The Ingersol looks like a nice upgrade. I assume the quality of Ingersol is high and the compressor will now outlive me. This one is on sale for $999 (if I remember correctly) until year-end. That's a hundred off normal retail at TSC. I run a metalworking shop, with plasma cutter, and a car service bay, and do fabrication and occaisional sand blasting in a cabinet.
Are there other compressors I should consider? Does anyone have experience with this Ingersol unit? Is there a better price available? Thanks.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #2
It sounds like you use the compressor quite a bit. I highly recommend the Quincy air compressors. They are not going to be in same price range as the TSC Ingersoll , but it will be the last you'll need. They give a high CFM output as well.
What makes the Quincy better? The Ingersol has a two year warrantee if using their oil, one year for Quincy. Cast iron two stage, AMSE tank and relief valve, same same same on both brands. Ingersol is 50% less money. Ingersol uses US made motor (I looked at the plate last weekend), Quincy unknown motor origin.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #6
Those two are not even in the same Ballpark. Quincy is a Industrial 100% duty cycle where as the IR is a 60%? Home type machine. If your using this a Home don't bother paying the bucks for the Quincy.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #7
Do you have a local IR dealer Vs on-line? I am not 100% sure but I believe at one time IR made different grades on compressors. Some lower quality for "box stores" & better commercial grade handled through authorized dealers. IR screw type are high volume lower noise but not sure what sizes they come in. Company I worked for installed 15 HP screw in 82 and it is still in operation today.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #8
As far as I know, the Quincy is designed to run a little slower, yet provide the same or more air, allowing it to run continually at 100% duty cycle.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #9
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #10
I'll take the low thump noise of a Piston machine over the screeching noise of a Screw feed any day.
1472 (A51247)
1472 (A51247)
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
CUSHMAN SHUTTLE GOLF CART (A51406)
CUSHMAN SHUTTLE...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
