I am looking at this air compressor at Tractor Supply - Ingersol 2-stage
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #1
jimgerken
Minnesota
John Deere 3720
Ingersoll Rand | TS4N5 Two-Stage Reciprocating Compressor
I need to replace a 5 hp single stage Puma, 60 gallon. The Ingersol looks like a nice upgrade. I assume the quality of Ingersol is high and the compressor will now outlive me. This one is on sale for $999 (if I remember correctly) until year-end. That's a hundred off normal retail at TSC. I run a metalworking shop, with plasma cutter, and a car service bay, and do fabrication and occaisional sand blasting in a cabinet.
Are there other compressors I should consider? Does anyone have experience with this Ingersol unit? Is there a better price available? Thanks.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #2
It sounds like you use the compressor quite a bit. I highly recommend the Quincy air compressors. They are not going to be in same price range as the TSC Ingersoll , but it will be the last you'll need. They give a high CFM output as well.
What makes the Quincy better? The Ingersol has a two year warrantee if using their oil, one year for Quincy. Cast iron two stage, AMSE tank and relief valve, same same same on both brands. Ingersol is 50% less money. Ingersol uses US made motor (I looked at the plate last weekend), Quincy unknown motor origin.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #6
Those two are not even in the same Ballpark. Quincy is a Industrial 100% duty cycle where as the IR is a 60%? Home type machine. If your using this a Home don't bother paying the bucks for the Quincy.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #7
Do you have a local IR dealer Vs on-line? I am not 100% sure but I believe at one time IR made different grades on compressors. Some lower quality for "box stores" & better commercial grade handled through authorized dealers. IR screw type are high volume lower noise but not sure what sizes they come in. Company I worked for installed 15 HP screw in 82 and it is still in operation today.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #8
As far as I know, the Quincy is designed to run a little slower, yet provide the same or more air, allowing it to run continually at 100% duty cycle.
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #9
   / I am looking at this air compressor at Tractor Supply - Ingersol 2-stage #10
I'll take the low thump noise of a Piston machine over the screeching noise of a Screw feed any day.
2005 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A54313)
2005 FREIGHTLINER...
2013 INTERNATIONAL REEFER TRUCK (A54607)
2013 INTERNATIONAL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
