MF 135 throttle diagram
   / MF 135 throttle diagram #11
Clutch disc? Isn't it the friction disc for keeping the throttle where you put it?
   / MF 135 throttle diagram #12
See my post above when i was referring to clutch disc i meant friction disc. Take a look at the entire linkage. One could reposition the throttle. The OP couldn't idle the engine with the replacement linkage. I suggested he adjust the linkage. With the adjustment behind the friction disc on the end of rod#4 is a clamp #27 that can reposition the rod for a higher rpm at idle. The other end of the rod adjust the friction disc tension.
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
INMY Manual Landing Gear (A51692)
INMY Manual...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
