MF 135 throttle diagram
   / MF 135 throttle diagram #11
Clutch disc? Isn't it the friction disc for keeping the throttle where you put it?
   / MF 135 throttle diagram #12
See my post above when i was referring to clutch disc i meant friction disc. Take a look at the entire linkage. One could reposition the throttle. The OP couldn't idle the engine with the replacement linkage. I suggested he adjust the linkage. With the adjustment behind the friction disc on the end of rod#4 is a clamp #27 that can reposition the rod for a higher rpm at idle. The other end of the rod adjust the friction disc tension.
2011 FORD F-550 (A53843)
2011 FORD F-550...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2015 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2015 Great Dane...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
1974 Trailmobile 40ft 30 Ton T/A Flatbed Equipment Trailer (A51692)
1974 Trailmobile...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
