Comparison Difference between MF-135 and MF-150?
   / Difference between MF-135 and MF-150? #1
slhilbert
Noblesville IN
Massey Ferguson 135
I have a MF-135, which I really like. The only thing I think I want on it that I don't have is a loader. Someone local is selling an MF-150 with a loader.
I looked into the differences between an MF-135 and MF-150 and from what I can tell there isn't much. I suspect that the MF-150 is a slightly larger tractor, but it seems to use the same engine as the MF-135. That seems to be a bit of a disadvantage to me.
Does anyone have any insight on the MF-150.
Thanks,
Stuart
   / Difference between MF-135 and MF-150? #2
Thanks,
Stuart
Bigger Front Axle that can support a FEL.
   / Difference between MF-135 and MF-150? #3
The 150 has a bigger front axle, a longer wheelbase that makes it feel less tippy, a larger operator station (which helps once you let the FEL levers rob you of some space in the wheelhouse), and a more solid feel when under a load.
At first glance, the criticism that a 150 is just an underpowered 165 sounds logical. However, it is difficult to work a 150 hard enough to run out of horsepower, and the more stable platform of the 150 makes it feel stronger than a 135.
I spoke to the gentleman today selling the tractor and he said it has a Continental Six Cylinder Gas Engine in it. I can't seem to find the specs on that engine matched to a 150 but I am sure he is right. I would guess that has a bit more horsepower than my 3 cylinder gas perkins.
Going to try to go check it out Friday so I might know more then.
Stuart
   / Difference between MF-135 and MF-150? #5
Righto. The front axle on my 1964 MF135 diesel looks like a toy compared to that on my 2008 Mahindra 5525 that carries an FEL with a 6-ft wide bucket and has about 3000 lb lift capacity at the pins to 10.5 ft height.
In addition, the MF135 does not have true power steering (provided by a hydraulic ram attached to the steering linkage on the front axle). The MF135 has "power assisted steering" provided by a dinky hydraulic gizmo on the steering column. Power steering comes in real handy when doing heavy duty FEL work. Muscling a MF135 around a hayfield is one way to get a good upper body workout. I assume the MF150 has the same arrangement as the MF135 for "power steering". I have seen photos of retrofits done on MF135s that add the hydraulic ram for true power steering.
Good luck
   / Difference between MF-135 and MF-150? #6
unlikely it has a 6 cylinder engine Either a Z134 four cylinder or a Z145 four cylinder.... Either way not enough difference to switch from a 135 to a 150 unless you are gaining power steering, live PTO or like new tires.
I had a mf 35 (precursor to the 135 ) with power assist and a FEl no issues for me in 15 yrs that I owned it
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
Kubota L3130 (A53317)
Caterpillar 906M (A53317)
Caterpillar 906M...
Ex Mark Zero Turn Commercial Mower (A59228)
Ex Mark Zero Turn...
2006 Sterling Acterra Rollback Wrecker Truck (A59814)
2006 Sterling...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
