Bobcat S150 skid steer vs. bobcat or kukota tractor...
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #1
DickeyJoe
Grass Valley, CA
Husqvarna yth1848xpt
Bobcat S150 skid steer vs. bobcat or kubota tractor...
So, here's the deal..
1. I have a lot, I mean a lot, of tricky landscaping ahead of me that will involve: some areas with pretty steep terrain, rocky soil, digging out least one pond along with dam construction; a lot of small tree removal; pushing over a lot of shallow rooted brush and making burn piles; a lot of gravel road maintenance, moving dirt around to alter the terrain in spots, etc.
2. I have very limited experience with both small kubota tractor/ backhoe and a rented small skid track bobcat with only a FEL. I don't consider myself a skilled or experienced operator, but do pay attention and can learn, especially from my mistakes. I am a lot better mechanic than I used to be.
3. I live in rural Northern California, and (with help from my grown son who is very mechanical minded with engines, hydrolics and the like) want to handle most of my own repairs and maintenance.
I'm thinking of a Bobcat S150, used with low hours if I can find a good deal on one, and, as $$ permit, a clamshell loader, backhoe with thumb, 6 way dozer blade, and maybe a flail mower. My son is a good welder and I envision making some pretty nifty attachments for removing small stumps, and ripping areas I will then push or scoop to get the terrain I want. I like the 49 hp engine, safety features, 16 GPM hydrolics and also keeping the "business end" in front of me as I work. What I am concerned about is getting in over my head with cost and repair issues.
Or.... I could get a kubota, say the L series. It would be a lot less money, easier to work on, but I fear a lot less machine for the jobs I need to do.
I guess I am not hiding my preference, but I would like to hear that I am overrating the bobcat and underrating the tractor option. I mean a lot of folk buy tractors that are not just for playing in a sandbox.....
Counseling would be greatly appreciated.
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #2
On steep terrain I'd prefer to have a tractor over a skid steer.
Is that because you could use a rear backhoe to stop a roll backwards? What's your thought?
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #4
I feel like a tractor is more stable on the steep ground and can go places the skid steer won't even go.
Thanks for the input....
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #6
I recently did something similar, bought an older skid steer to move dirt into my backyard that has a decent slope. It was a no-go, the skid steer had to come out in reverse, wouldn't make it up the hill forward, just started bouncing and trying to tip backwards.
I sold the skid steer and rented a bx25 to get the job done.
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #7
It sounds (to me) like your on the right track with the SS except for the slopes. If you added the "over the tire" steel tracks to your wish list it will make a huge difference in traction and add some stability on the hills. IMHO most all tractors fel's are really built for chores or loading loose material from a pile. For real "ground engagement" digging & rooting out stumps, a SS is designed for hours of that, whereas a tractor is basically designed to pull, with the loader being an obvious simple add on handy attachment that makes a tractor more versatile around the farm.
That go's for my 9540 as well. It's not about size but intended design purpose. From your project list, it sounds like you might also consider an excavator as one of your choices.
Thanks for the point about tractors being the pulling machine that replaced the horse. They do good work but I'm afraid that, for what faces me, I'm looking for a digger and pusher more than a puller. Now, to convince my wife I won't be digging my own accident grave and paying a lot for the privilege!
   / Bobcat S150 skid steer vs. bobcat or kukota tractor... #9
My compact telehandler will out work a skid steer for digging and everything else!
With a grapple.
With a 7' brush hog.
With a 6' boxblade on a three point adapter on a tilt-tach
Check this thread: http://www.tractorbynet.com/forums/...t/160568-compact-telehandler.html#post3243370
Wow.. That is one amazing rig you have there! Wish I could afford half of what I see there. Really "versatile" as the name implies. Thanks for the idea. It does widen my horizon.
Deere 310SK (A57148)
2005 TerraGator 8104 (A55302)
2005 TerraGator...
2019 GALYEAN...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Unverferth 25' Head Cart (A59814)
Unverferth 25'...
