New Grapple, new tractor guy
   / New Grapple, new tractor guy #21
Thanks for the replies, makes sense. I guess that I don't plug and unplug stuff enough that I even give it much thought. I have just always thought of the flat faced QDS for industrial use. From what I have seen, even the BIG AG tractors still use the typical AG style QDs. But maybe that's changing too. :confused3:
The Kubota 3rd function does not come withs QDs. My dealer put a the flat faced QDs on for free, he was working on selling me skid steer blade.
Interesting Top Link holder.:scratchchin:
I knew somebody would say something about that. I had just got the tractor when I took the picture.
I upgraded to a tarp strap.
Now the QH holds it.
Sent from my GT-P3113 using TractorByNet
Called the Kubota dealer and they tell me that the lines are fitted with -8 JIC. Looking at the site K0ua posted, I cant find any with a JIC fitting on them.
   / New Grapple, new tractor guy #23
Not sure what you mean. There thousands of the jic fittings on that site. You need a jic fitting to npt fitting
. What sex l dont know as you did not spec the sex of what is on you Kubota. A pix would be worth a lot. Also are they on a bracket now? Do you need 90 degree turn? I really can't find what jic to ntp connector adaptor you need without that pix.
   / New Grapple, new tractor guy #24
. What sex l dong know as you did not spec the sex of egst is on you Kubota. A pix would be worth a lot. Also are they on a bracket now? Do you need 90 degree turn? I really can't find what jic to ntp connector adaptor you need without that pix.
He does not need a 90.
Sent from my Samsung SPH-L710 using TractorByNet
   / New Grapple, new tractor guy #25
I just took a picture of mine.
   / New Grapple, new tractor guy #26
Is the jic female? How is it mounted? Or is it just hanging there ?
   / New Grapple, new tractor guy #27
The FF coupler number on mine is FEM-502-8FP. If you look up that number that should tell you what it is, I can't right now. I guess they would be the same.
   / New Grapple, new tractor guy #28
Well I would ask how much came with the tractor and how much does he need to order (except in AG not FF couplers). Does the bracket come with the tractor? did the -8 JIC to 1/2 inch NPT bulkhead adaptor come with the tractor?.. What I need is a picture of his tractor.
   / New Grapple, new tractor guy #29
Roger are you saying you just added the FEM-502-8FP ? flat face coupler, screwing it on to the 1/2 NPT to 8- JIC bulkhead connector already on the tractor?.. What I am trying to determine is what does the tractor look like when it comes from the factory prepped for the 3rd function?.. If all you have to do is screw on the connectors, then all he needs is a set of AG 1/2 inch quick connectors, one male and 1 female as they will have 1/2 NTP fitting on them. He wont need any bulkhead adaptors JIC to NPT or not have to make a bracket or anything.
   / New Grapple, new tractor guy #30
I am not sure what all comes with the kit, the dealer put the FF couplers on mine. I am pretty sure I have the instructions for the 3rd function. I can look in a couple of hours and see what the instructions say.
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
18in Wain-Roy Tooth Bucket (A51573)
18in Wain-Roy...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
