Winter fuel additive
   / Winter fuel additive #11
Howse makes an excellent product.
In some 'study' (not sure how scientific) the Howes got better reviews than the Power Service (white bottle) for anti-gel protection..
FYI - Power Service comes in at least three different bottles White, Silver, and Red (which is an emergency solution to unthawing already gelled fuel).. I always used the white bottle as my anti-gel until i switched to the howes..
Northern Tool, Pilot Truck Stops and a few other T/S carry the Howes
Brian
   / Winter fuel additive #12
I've been using the White Power Service for years and have never had any fuel related issues.
DEWPO
   / Winter fuel additive #13
Schaeffer's Diesel Treat 2000 Winter Premium is an exceptional product. An on-line study can be found at dieselplace.com. The Schaeffer additive tested is the winter blend.
++1 on the schaeffers diesel treat.Great product IMHO.coobie
   / Winter fuel additive #14
Living in Minnesota (straight west of Duluth) and I use Schaeffer Diesel Treat 137ULSW. Besides winter protection, you get lube, extra cetane, sits on water; just read the can.
I do a 50/50 blend and 1 oz of Schaeffer (my fuel barrel is a 5 gallon can) and a sample was sent in for cold weather testing; the CFPP came in at -51 degrees ... I have never gelled up.
I also use a block heater and I used to have a battery blanket, but it died ... I like a battery blanket. Heat is good, at -20 below, if I plug the tractor in for a couple of hours; the tractor will start right up on the first glow plug cycle.
I use the winter fuel additive year around, I don't go through a lot of fuel, so a pint can goes a long way for my at home wood hauler / snow fighting tractor.
Right now, I am dragging my feet on when I purchase more fuel; I will first add in a couple of gallons #1 and going into winter, then I do the 50/50 blend plus the additive, by early December, I will be into a 50/50 blend and the additive.
I need to change the fuel filter .... to easy to over look the fuel filter and per a dealer that sells small compact tractors to hobby farms; the biggest problem that their shop sees is dirty fuel filters.
The tractor is a 3 cylinder Mitz ... a grey market tractor.
   / Winter fuel additive #15
I put just about 100 to 150 hours on my tractor. I service it every fall, always change the fuel filter.
   / Winter fuel additive #16
I'm going to add in a totally stupid question. I live in SW Ohio. This is my first year with a diesel tractor. In general we never get below 0 degrees with limited exceptions (late Jan/early Feb if that).
I'm doing diesel in five gallon containers. So my questions:
Being mid-November -- are most diesels stations in the area selling the winter anti-gel grade?
Is there an issue if I add anti-gel stuff to diesel that is already an anti-gel diesel; will it mess anything up?
   / Winter fuel additive #17
I live in MN, the center of the state, by Christmas; I look for -30 below aka we get cold. Right now, I am going to put in some #1 and additive ... but can you get #1?
Even if you use straight number 1 dsl; the additive will add lube & cetane, sit on water.
If your fuel is a winter blend and already treated with a winter fuel additive, you will not harm your tractor or fuel by putting in more. The fuel testing that I have seen, double treating the fuel will not get / buy you much more cold temp protection; but you will get extra cetane and lube.
I also buy my dsl fuel in a 5 gallon can and if your temps are correct, then I would go with straight #2 with a fuel additive, I use one ounce of Schaeffer in my 5 gallon jug and that will push your dsl fuel down to a -30 below cold filter plug point.
By mid December; I will be using a 50/50 blend and the additive.
Fuel filter ... change it once a year, in the fall.
   / Winter fuel additive #18
I'm going to add in a totally stupid question. I live in SW Ohio. This is my first year with a diesel tractor. In general we never get below 0 degrees with limited exceptions (late Jan/early Feb if that). I'm doing diesel in five gallon containers. So my questions: Being mid-November -- are most diesels stations in the area selling the winter anti-gel grade? Is there an issue if I add anti-gel stuff to diesel that is already an anti-gel diesel; will it mess anything up?
I live in Northern MN. Our supplier starts delivering #1 in late October. We use that in the tractor that does most of the farm chores. The other tractor we use in winter gets fuel from a station in town on which they label the pumps in mid-October when they start using a cold flow additive in addition to regular #2 diesel. I have checked all 3 stations in town that sell on-highway diesel and they have #2 plus cold flow additive stickers on the pump. However we had a guy come up from Central IL and his diesel pickup wouldn't start on a cold morning. It got warm enough during the day to start and he filled with local diesel and no longer had any problem for the 2 weeks he stayed. We don't like to run the winter diesel any longer than needed because fuel economy gets very bad with #1, or even a #1/#2 50/50 blend. That is what our distributor said as to why they quit selling the blend and instead changed to a cold flow additive. Sell less fuel but no customer complaints about poor fuel.
   / Winter fuel additive #19
#1 dsl, has less BTI than #2 and there goes the mpg.
When I ran my F350 Ford with dsl engine; I ran #2 and Schaeffer winter fuel additve. If the temp went below 0, I would start putting in #1 ... 80/20 or 70/30. One day in Ely,MN; it was midafternoon and -45, and I dumped in all the #1 I could with the fuel additive, then I found a hotel room and plugged in. In the morning it was -55 and she popped right off. After she warmed up, I went to International Falls ... it had warmed up to -20, a heat wave. The morning in Ely, a truck from the Twin Cities, with metro fuel; he was gelled up. In the metro, no number 1.
I travel in NE MN on business, were are you at? I live at Deerwood, just west of Aitkin.
   / Winter fuel additive #20
I have a Mahindra Max25 SCUT. Most of my winter use is going to be clearing my driveway with the FEL, and maybe neighbors.
My hourage is about 3 hrs/gallon.
So if I grab the diesel now I should probably good for the winter.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
CAT 973 (A47384)
CAT 973 (A47384)
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A51572)
2019 Ford F-550...
2013 Yamaha Golf Cart (A51573)
2013 Yamaha Golf...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
