front tractor tires
/ front tractor tires #1
MESSMAKER
Bluegrass,KY
DK4710SE
I need a set. Size 25-8.50-14 commercial tread.. They are running about $175 locally for each tire plus install of about $15.Bobcat wants about 2 bills for each tire. The last set I got a little less than 2 years ago and paid about $225 for both. I know tires have gone up but this seems a bit much.
/ front tractor tires #2
Maybe the set you got recently and need to replace now were cheap Chinese junk and that's why you are shopping tires now. Tires have gone up a bunch: compare brands & ply ratings to get a valid comparison. If you don't know what BRAND and PLY tires you are pricing, you can't determine the value.
/ front tractor tires #3
What are you doing to wear out a set of tires in one year. Are you travelling a lot on hard surface (black top or concrete) and maybe keeping it in 4 wheel drive. No way a set of tires would wear out in a year of normal tractor wear. By commercial tread I assume you mean R 4 tread which is Industrial tread.
I run a rotary mower for hire. I am in all sorts of areas, but very seldom on blacktop. I got 2+ seasons on the Bobcat tires and I am going to get about the same on the Ebay tires. I do run in 4wd almost all of the time.
John Deere TX Gator (A60462)
John Deere TX...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63688)
2023 Kubota L3560...
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
