Concrete estimate sounds high to me???
   / Concrete estimate sounds high to me??? #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
Hey guys I got an estimate today on a 25x30 4" parking pad. The ground is level and easy to access. The guy came buy getting business for his and his sons company. This guy is in his 80's and just drives around and sells jobs 2 or 3 days a week or so he says.
His price quote was 3700 for the job. The estimate on concrete was 10 yards and that came out to about $1000. $2700 in labor sounds awful high to me. Level ground, easy to grade and frame and get the concrete to it??? Thoughts????
Thanks
Wade
   / Concrete estimate sounds high to me??? #2
270 a finished yard is very high. Its about 200 to 225 here depending on the prep and psi rating.
   / Concrete estimate sounds high to me??? #3
did it include creating any kind of base or machine work (excavation, spreading, etc)?
   / Concrete estimate sounds high to me??? #4
Shop around, you never know the going rate until you find out what others are charging. Of course, the best is going to charge more because he can get it and there will be a wait for them to get to you. When I was looking around for guys to spread and level the concrete for my parents house, I got prices from a buck down to .50 cents a square foot. I built the forms and set the rebar, they just showed up and made the concrete look nice. They where there about six hours. I went with the guy who wanted .50 cents a square foot.
Eddie
   / Concrete estimate sounds high to me??? #5
It is about $3.50/ft^2 X 6" here. That includes compacting, base gravel spreading and againg compacting, rebars foot on center, chairs, framing, conrete delivered and pumping. Cost of gravel and ground leveling not included.
   / Concrete estimate sounds high to me??? #6
It's running about 3.75 sq ft here . Covers everything.
He's a little high. get a few more estimates.
   / Concrete estimate sounds high to me??? #7
Looks like Ohio and CT have about the same prices. Labor for a small pour like that would run you about $80 - $100 a yard around here.
Thanks guys. The price was for everything. He said nothing about rebar but did say he includes fiberglass. I guess that is in the mix???
This guy just happened to stop by. He wanted to estimate my 1100' driveway. No wat I could afford that so I did not get an estimate. I have 2 more people right now. I was both of their kids basketball coach so maybe they will cut me "some" slack....
Wade
I was expecting 1500-2000 max but I may be way off!
   / Concrete estimate sounds high to me??? #10
The last concrete work I had done was a bit different from most residential work I have seen. The guy actually used a vibrator which I have never seen in residential work. He had a commercial concrete background. http://www.concreteconstruction.net/images/Concrete Vibration_tcm45-341602.pdf Vibrstrike Concrete Vibrator _ New York_ « Biordi Conctruction Less likely to have concrete popping off or weak voids if you have it vibrated.
I guess I am saying you can have a bubba install or a pro install and you might not know the difference. Or you could get 3 bids and they are all bubba installs.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
New Swict 66" Skidloader Bucket (A50775)
New Swict 66"...
NEW HOLLAND TN95EA TRACTOR (A54756)
NEW HOLLAND TN95EA...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
