New 955 Need to Swap Power Beyond from 755
   / New 955 Need to Swap Power Beyond from 755
Yes I have a mig. I am not ready to weld a bolt to it yet. The hex is not rounded out yet.
If they used green thread lock on it, I am going to try some heat to the plug with a small torch. I want to make sure I am not going to do any damage to the internal parts.
I think tomorrow I will try to get a short allen 3/8 drive. I have been getting a lot of flex do to the length of the allens. I may be able to put more torque to the plug with a shorter one.
I think we are working on the barn in the morning, so it might be a few days before I try again.
   / New 955 Need to Swap Power Beyond from 755 #12
Yes I have a mig. I am not ready to weld a bolt to it yet. The hex is not rounded out yet...
The suggestion to weld a bolt to it was more of a way to sink a bunch of localized heat into the plug to help break it loose. Actually, in this case, I would plug-weld a nut to the plug through the center hole in the nut. First step would be to fill the hex socket in the plug with weld, then plug-weld the nut to the plug. Then you could get after it with a six-point socket and breaker bar if need be.
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2017 Ford E-450 Passenger Bus (A56858)
2017 Ford E-450...
10,000 PSI AIR HYDRAULIC PUMP (A58216)
10,000 PSI AIR...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
THREE POINT ATTACHMENT (A58216)
THREE POINT...
