Grapple On!
   / Grapple On! #1
adventure bob
Here
JD 345/ Kubota Side by/ kubota ??
This thing went on real easy, picks up everything and looks **** cool on the front of a tractor.
   / Grapple On! #2
Let us know how you like that Grapple. I am looking at buying one of the smaller ones.
   / Grapple On! #3
I sure like my EA "wicked" 50 inch single lid. It has done everything I need so far.
   / Grapple On!
I have moved about 6 16 foot trailer loads of slash, a couple of really big stumps and crushed the pallet it came on. I have a forest of burnt trees to take out so it'll be used. The thing I really like is when cutting logs into fire wood lengths, you pick em up to working height and go to town with the chainsaw. No more bending down and no more stabbing the chainsaw into the dirt by accident.
So far Im loving it. I do need some weight on the back end though. Got tippy a couple of times moving some bigger stuff. I've had the tractor just over a month or so and it'll be going in for its 50hr before Christmas. I'm gonna have 'em fill the tires with Rim guard. I can see how you could end up on your side really easy.
   / Grapple On! #6
The Rimguard will help a lot, but you still need some 3pt weight too to gain the maximum ability of your loader and to help "unload" your front axle. The Rimguard will help too when you are on sidehills to lower the center of gravity as the majority of the Rimguard will be below the rear axle, and will also help if you pull ground engaging equipment (boxblades, grader blades plows etc)
James K0UA
   / Grapple On! #7
That's a good looking grapple. You'll wonder how you got along with out it. I only have a bucket grapple but, it's better than no grapple at all. Where you located ??? All that snow !!!! We will get snow once in a blue moon down here!!!
   / Grapple On!
Were getting hammered right now. The snow you see in the pics is a light dusting. Ill get a snowblower eventually. I have a small JD with a big blower on it, but it doesn't have the coziness of a cab with heat. I have to bundle up like I'm going to walk though the Siberian outback when I use it.
   / Grapple On!
Colorado Springs
HURRICANE 7' X 12' CONTAINER (A51248)
HURRICANE 7' X 12'...
UNUSED JCT 84" HYD 4N1 BUCKET (A51248)
UNUSED JCT 84" HYD...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51246)
KNOW BEFORE YOU...
2016 Ford F-250 Reading Service Truck (A51692)
2016 Ford F-250...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A51246)
2020 CATERPILLAR...
