Grapple On!
/ Grapple On! #1
adventure bob
Platinum Member
Here
JD 345/ Kubota Side by/ kubota ??
This thing went on real easy, picks up everything and looks **** cool on the front of a tractor.
/ Grapple On!
I have moved about 6 16 foot trailer loads of slash, a couple of really big stumps and crushed the pallet it came on. I have a forest of burnt trees to take out so it'll be used. The thing I really like is when cutting logs into fire wood lengths, you pick em up to working height and go to town with the chainsaw. No more bending down and no more stabbing the chainsaw into the dirt by accident.
So far Im loving it. I do need some weight on the back end though. Got tippy a couple of times moving some bigger stuff. I've had the tractor just over a month or so and it'll be going in for its 50hr before Christmas. I'm gonna have 'em fill the tires with Rim guard. I can see how you could end up on your side really easy.
/ Grapple On! #6
The Rimguard will help a lot, but you still need some 3pt weight too to gain the maximum ability of your loader and to help "unload" your front axle. The Rimguard will help too when you are on sidehills to lower the center of gravity as the majority of the Rimguard will be below the rear axle, and will also help if you pull ground engaging equipment (boxblades, grader blades plows etc)
James K0UA
/ Grapple On! #7
That's a good looking grapple. You'll wonder how you got along with out it. I only have a bucket grapple but, it's better than no grapple at all. Where you located ??? All that snow !!!! We will get snow once in a blue moon down here!!!
/ Grapple On!
Were getting hammered right now. The snow you see in the pics is a light dusting. Ill get a snowblower eventually. I have a small JD with a big blower on it, but it doesn't have the coziness of a cab with heat. I have to bundle up like I'm going to walk though the Siberian outback when I use it.
/ Grapple On!
Colorado Springs
/ Grapple On!
Its a 66" Wicked. Loving it so far and it seems like itll stand up to abuse.
/ Grapple On! #14
Very nice looking tractor and grapple. You will love having a grapple.
2008 Ford F-250 Pickup Truck (A61573)
2008 Ford F-250...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
John Deere 4240 w/ Loader and Hay Spear (A64047)
John Deere 4240 w/...
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
