Hot asphalt in their 14' goose neck dump trailer?
   / Hot asphalt in their 14' goose neck dump trailer? #11
To everyone who suggested using some type of fuel oil as a release agent; They should realize that this is a very poor historic hauling practice that has contributed to the failure of many miles of roadways due to the contamination of the aspahlt mix. Please do not endorse/suggest this unless its for your own private use. Truckers will swear by the practice but have very little interest in the longevity of the HMA as opposed to keeping their trucks clean. I am not very familiar with HMA but I do believe that they have a release agent specifically for use in truck bodies to get the mix out. Most haulers (in this area) have heated beds and vibrators to help dislodged the material.
As for the recycled asphalt, check with your local regulations. In PA for instance, you cannot leave the recycled asphalt exposed to the elements in a road because it leaches petroleum products more easily than a placed mix will. It may be used as a sub-grade only and then sufficiently capped. The price of the binder has gone up so much that most companies recycle it to save on their costs and are not very likely to give it away.
   / Hot asphalt in their 14' goose neck dump trailer? #12
They have a tank at the asphalt plant here that they use to put fuel oil on the truck bed before getting a load but I see your point.
   / Hot asphalt in their 14' goose neck dump trailer? #13
In Florida, technically, your supost to use "non petroleum based soap solution" and there is a orange oil based product. The amount of diesel I'm talking about is probably less than a pint sprayed over the bed, and should not affect the asphalt durability.
   / Hot asphalt in their 14' goose neck dump trailer? #14
When you buy any of these recycled materials how do you know that they are contaminant/pollutant free? The RCA I've placed in my driveway from time to time obtained from the local supply yard seems to have anything and everything in it; concrete chips, rebar, brick, asphalt, soil, shreds of black plastic film, I even saw a condom in it one time. My guess is a lot of building demolition material is being ground up and mixed in. How would you know if asbestos debris was in there? Do the states regulate and inspect any of this stuff? I ask because some of the operators of these recycling/sand mine/quarry places don't always seem to be the most scrupulous of business persons.
   / Hot asphalt in their 14' goose neck dump trailer? #15
I would not expect the paint or the wiring to be affected by the heat. As stated above the asphalt should be 300 degrees plus or minus as it comes out of the silo at the plant. If you really want to make sure you could place some pieces of plywood on the sides. As part of my job, I test and inspect asphalt, part of which involves inspecting the plants. I live in Washington and in my state diesel is not allowed to be used on the boxes, the plants have a station for spraying a release agent that is supposed to be non hazardous.
I hope you have helpers and reasonable equipment. Without this, your project can quickly turn into a disaster, I have seen them. Spreading asphalt is not the same as spreading gravel, and it needs to be compacted before it gets too cool. If it is not compacted before it cools it will not have a long life especially on a hill.
For those recommending to use recycled materials, I agree that they can be superior to virgin rock. In my state there is a law that requires the company that processes and sells the material to have it tested every for hazardous materials.
   / Hot asphalt in their 14' goose neck dump trailer? #16
rent a small kettle, buy the asphalt kegs and do it yourself. careful you'll need ALL high heat buckets and equipement to do it.
   / Hot asphalt in their 14' goose neck dump trailer? #17
Hes doing a driveway not a roof? unless your suggesting tar and chip instead of compacted asphalt concrete.
   / Hot asphalt in their 14' goose neck dump trailer? #18
Same diff. Use with pea gravel. Spray the hot asphalt, spread pea gravel, or even cheap slag as on a roof, spray more asphalt. works on roofs for 20 -25 yrs. Why not a road? Do you only eat eggs for breakfast???
   / Hot asphalt in their 14' goose neck dump trailer? #19
Thats basically what we call Chip Seal. A tack wagon or tack truck sprays the rock, and you spread rock. Its not a bad product/process, but its roughly $2.40/sy in large quanity for single coarse (1/2" rock on tack) compared to $5.00/sy/1" of asphalt (once again in quantity). You get a inferior product at less than substantial savings. It requires speciality equipment (tack truck, rock spreader, and traffic roller) and he still needs to haul in 1/2" granite chips at $20-30/ton. I agree with idea, lay 1-2" of asphalt (110-220#/sy) roll with small/medium roller or in small areas use plate compacter; and be good for next 15 years
Sorry for the delay but I have been working. As far as equipment I should be reasonably set. I have a Mitsubishi dozer, 2 30/40 hp tractors, and a brand new PJ dump trailer, as far as compaction I have a old 10’ long 40” tall / 325 gallon propane tank I want to build a roller out off. The roller should weight approximately 4000lbs and would even consider purchasing a walk behind compaction plate. I was also think about building a 10’ wide spreader box to lay a consistent layer of asphalt. I have little better that a ½ mile of road to my house down a private road so if I can make this work I would slowly do it all as my funds become available. The 400’ section I want to start with is the steepest section of the road the rest is reasonably flat or rolling hills. I have spent thousands of $ on this particular section of the road over the past 10 years due to washing down hill and feel like I am flushing money down the toilet so need to change my tactics on it. As far as spraying fuel oil in the dump trailer would not be a problem or a concern. I would not mind chip seal on top over good road base just need something to bind the material together to keep it from washing. There is about a 25-30 elevation change in this particular section of the road. I have considered pouring concrete in this area but can not afford to pour the entire 1/2 of road. So I am open to all suggestions.
Regards,
Tim
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
New/Unused 10ft 40 Drawer Workbench (A51573)
New/Unused 10ft 40...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
