3-Point Hitch 1987 SL1643 Shibaura controls
   / 1987 SL1643 Shibaura controls #1
lifeundersol
Algoma, WI
SL1643 Sibaura
I am new here and just purchased a Shibaura SL1643. I am finding out how hard it is to get any information on this unit. From my searches I believe A Ford 1310 is the closest sister to my tractor. My question is...what are the controls on the right fender used for? They do nothing when moved.
   / 1987 SL1643 Shibaura controls #2
I think mine is a 2443. From what I can find out the controls ron a rototiler for the rice paddys. The first control should be an oversized toggle. That controls the 3ph up and down. When mine worked right , one knob controlled the speed that the hitch raised and one controlled the height. l have had to run a hot wire to the circuit board to keep mine working. The 3ph drifts down and I'm not sure if thats the solenoid or the hydraulics. mine has been a good tractor. Bent and abused but it will still pull good and pickup a roundbale when it has to. The 4wd has never worked and I put truck tires on the front and I start it with a screw driver.I cant wait for my boarding business to pickup so I can buy a new tractor.
Thanks for the info. I have the control box off and found a broken wire going to one of the pots so I will resolder it. I just got the tractor and have not looked close at it yet, but where is the circuit board? The wire harness disapears under the seat.
   / 1987 SL1643 Shibaura controls #4
The circuit board should be in the control box. The harness I guess goes down to the solenoid on the rear end. I used a test light and checked the wires in the box and found one that looked like it should have been hot. I ran a jumper to it and my 3ph started working again.
I can tell you if your 3 ph works leave the box alone. if its not working, the knobs need to be in a certain spot for it to pick up. Maybe yours has been put back to work with the the orginal hydraulic pickup. Let me know what you find out!
Ya, I found the board after I posted,sorry. But there are 2 loose wires in the hardess that have connecters going no where with no other mating connecter in the box. I am asuming these are for a function my tractor does not have, just spares.
What certain spot are you talking about with the knobs? All I know is the guy I bought the tractor from was pulling a linkage lever under the set to operate the 3ph. The control box is not working. I sure wish I could read Japanese it would be nice to know what the knobs are labeled.
Thanks for your time.
excavator trenching bucket- one bucket per lot (A56436)
excavator...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A55973)
2015 SkyJack SJ86T...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
MUFFLER PIPE (A58374)
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
