Soffit carpentry question
   / Soffit carpentry question #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
Cornice, soffit carpentry question. I have some trusses set at 2' on center and 24" deep for soffit .Sub fascia in the front no nailer in the back. Can I use 1/2" BC plywood for soffit with a 2" continuous vent, which would make the 1/2 pieces about 11" wide x 8' long.
   / Soffit carpentry question #2
I guess you could use 1/2" plywood, but I just don't understand why you would want to? Just did my soffits although we only have a 12" overhang and ran a continuous vent down the center. There doesn't seem to be a need for thicker plywood material.
   / Soffit carpentry question #3
Sure...what is the siding on the building?...
If the soffit is going up after the siding you can use a trim strip etc...I would recommend priming/painting all edges of the plywood (including the but joints)
2" is not much of a vent though...can you not open it up to 4" ?
2" x 8' pieces is how it comes from the lumber yard . the other option would be 8" x 16" squares and leave the 1/2" plywood 24" wide
   / Soffit carpentry question #5
How is the attic space ventilated?...that is the factor in determining the amount of venting needed at the soffit...
with just about any circular saw you can use a cheap rip fence (that connects to the saw) and rip the panels down...
is there a reason you do not want to go with something like aluminum or vinyl soffit?...it is much more on the maintenance free side...
gable vents on both ends 4/12 pitch 28' wide 64' long. old school not familiar with vinyl could see if the local lumber yard carries it.Thanks for the reply. 12' x 12" vinyl cut into 2' sections with J channel is what you are suggesting
   / Soffit carpentry question #7
yes that would work...the "J" channel trims the building edge...use "L" or "F" channel along the sub-fascia or use aluminum fascia that has the "L" break...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A54814)
2016 Autocar...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A54757)
UNUSED RAYTREE...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
Frontier FM2015 (A53314)
Frontier FM2015...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
