Soffit carpentry question
   / Soffit carpentry question #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
Cornice, soffit carpentry question. I have some trusses set at 2' on center and 24" deep for soffit .Sub fascia in the front no nailer in the back. Can I use 1/2" BC plywood for soffit with a 2" continuous vent, which would make the 1/2 pieces about 11" wide x 8' long.
   / Soffit carpentry question #2
I guess you could use 1/2" plywood, but I just don't understand why you would want to? Just did my soffits although we only have a 12" overhang and ran a continuous vent down the center. There doesn't seem to be a need for thicker plywood material.
   / Soffit carpentry question #3
Sure...what is the siding on the building?...
If the soffit is going up after the siding you can use a trim strip etc...I would recommend priming/painting all edges of the plywood (including the but joints)
2" is not much of a vent though...can you not open it up to 4" ?
2" x 8' pieces is how it comes from the lumber yard . the other option would be 8" x 16" squares and leave the 1/2" plywood 24" wide
   / Soffit carpentry question #5
How is the attic space ventilated?...that is the factor in determining the amount of venting needed at the soffit...
with just about any circular saw you can use a cheap rip fence (that connects to the saw) and rip the panels down...
is there a reason you do not want to go with something like aluminum or vinyl soffit?...it is much more on the maintenance free side...
gable vents on both ends 4/12 pitch 28' wide 64' long. old school not familiar with vinyl could see if the local lumber yard carries it.Thanks for the reply. 12' x 12" vinyl cut into 2' sections with J channel is what you are suggesting
   / Soffit carpentry question #7
yes that would work...the "J" channel trims the building edge...use "L" or "F" channel along the sub-fascia or use aluminum fascia that has the "L" break...
2025 Wolverine TQH-26-02C Class 2 3-Point Hitch with 2in Receiver Trailer Mover Attachment (A52378)
2025 Wolverine...
2019 MultiQuip Mayco C-30HDGA 3in Towable Concrete Pump w/ Hoses (A52377)
2019 MultiQuip...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2007 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52705)
2007 GENIE...
