How to remove Battery Cable bolt
   / How to remove Battery Cable bolt #1
JeffandTamara
Kentucky
Kioti DK35, Case 1190
I need to replace the battery in the Kioti Tractor. The Battery cables are a little correded but not that much. I can't get any sockets to fit the bolt. I don't know what the problem is, but no sockets I have metric or SAE will get a bite on the bolts (Pos and Neg) I would like to cut the bolds off somehow. My first choice would be a dermel, but afraid that might go Poof! I know(Hope) there are probably some tricks that someone might have up there sleeve. What do you think??
   / How to remove Battery Cable bolt #2
Wash it down with Baking soda and water a 10mm should fit.
Yes, I thought 10mm should have fit, but it seems to spin on th bolt(s)...
   / How to remove Battery Cable bolt #4
I don't know what the problem is, but no sockets I have metric or SAE will get a bite on the bolts (Pos and Neg) ?
Jeff,
Are you using a deep socket? I need to use one when I am connecting/disconnecting the battery on my tractor.
Steve
Yes,,,deep wells, open end wrenchs, metric and SAE...The bolts are a bit rounded off, Probably what is going on.
   / How to remove Battery Cable bolt #6
Time for vice grips, make sure their tight before turning.
   / How to remove Battery Cable bolt #7
You can try a set of vicegrips.
Sorry, Murph beat me.
   / How to remove Battery Cable bolt #8
That much corrosion, figure on replacing the clamp. Just cut the cable. :)
   / How to remove Battery Cable bolt #9
using a hammer on the socket keep tapping the socket onto the nut, use a good shot of whatever pentrant you have to help, but getting it to start is half the battle, even if you twist/break off the the stud or the nut, your replacing the battery anyways, buy a new nut whan at the store.
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
2010 FORD F-150 (A53843)
2010 FORD F-150...
TMA (A49461)
TMA (A49461)
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
Small Trailer frame (A53117)
Small Trailer...
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
