copper pistons
   / copper pistons #1
daugen
Epic Contributor
New Hope PA
in between now
2014 Ferrari 458 Speciale First Drive - Motor Trend
this is a little far astray, but some interesting new high performance ideas, two of which puzzled me.
But I'm sure one of you know.
Ferrari even went so far as to add copper to the pistons, making them conduct and dissipate heat more efficiently while increasing tensile strength.
How does adding a super soft metal like copper increase tensile strength? I understand the heat dissipation, think Revere Ware pan, but clearly my metallurgy understanding is woeful.
and my chemistry isn't much better:
next-gen HT2 brake discs with added silicon
Now silica I understand in a brake pad, but silicon(e)? Ok, I looked it up, and they are all related.
Silicon is the basis of the ubiquitous synthetic silicon-based polymers called silicones.
so we have something that is both very hard and used in industrial abrasives and also something that can be extremely slippery.
I guess that's why the chemists get the big bucks, but I could not imagine why anyone would use what I knew as drawer and window lube in the chemical compounding for brake pads. Must be the industrial grit relative.
When brakes become a ten grand option, or way more than that in certain cars, you have to wonder what justifies that.
The Brembo brakes standard in front in my XTS are some of the best I've ever had. Serious bite without the vibration or grinding.
Tractor brakes sure are simple, aren't they? they probably still use something good like asbestos...
   / copper pistons #2
most modern (last 20 years) wet disc type brakes use paper based fiction material.
   / copper pistons #3
I do know that some engines built in the very early days of internal combustion engines actually used steel , but when pushed- the pistons dome would deform due to the heat.
When aluminum was first tried -many were worried that the pistons would soften and melt, but the Aluminum transferred heat so much quicker that the softening became a non issue...
Another little tid- bit concerning diesel engines was the addition of a third compression ring, which I assumed was for the main purpose of reducing leakage during combustion,
It is actually more useful for heat transfer.... The dome gets the hottest and the major means of dissipating the heat- out of the piston is thru the rings to the cylinder walls and into the coolant.
A small article i read recently described how some marine diesel engine designers were derided- for not staying up with the times and asked why they couldn't make a 2 compression ring piston work-
So the company tooled up some new 2 compression ringed pistons, and tested their established design of marine diesel engine with the (new piston and rings) the result was over heated pistons in a very short order....
I guess that's why I have yet to see a diesel engine design employing only 2 compression rings... but do see engines with oil cooling jets...
   / copper pistons
I never knew that, assumed heat went more vertical and was water cooled in the combustion area. But those rings sure touch all the time, so this makes sense to me.
   / copper pistons #5
I would imagine that they add enough copper to aid heat transfer but not enough to significantly affect the strength of the metal somehow.
   / copper pistons #6
I don't fully understand all of metallurgy either. But alloys of metals usually end up with better properties.
Like solder for example. Tin and lead have a specific melting point. When combined, it is higher than either.
Or adding softer nickel to steel to get stainless alloys that is harder.
   / copper pistons #7
Or like mixing sulfuric acid and hydrochloric acid together to dissolve gold when neither of them alone will affect it.
   / copper pistons #8
If you got gold that needs to be destroyed, I'll take it..
   / copper pistons #9
its more than a century old, read here: Duralumin - Wikipedia, the free encyclopedia
carbide tips for table saws, are actually silicium carbide, also a silicium containing alloy.
Silicon - Wikipedia, the free encyclopedia
   / copper pistons
thanks Renze, really interesting, I must have been snoozing in high school chemistry class.
Four percent or slightly more copper adds strength to aluminum, but causes it to be more susceptible to corrosion, so
it is clad again with aluminum in aircraft use. Got it.
So if a piston mfg was going to add extra copper to a piston for better heat transfer, then it would make sense that improved
corrosion protection would also be built in. The Germans/Mahle have always been coating their bores with something exotic.
Nikasil? There's that "sil" again...
Carbide is amazing stuff. Just like a lot of the exotic ceramics, some of which I think were made for the space program.
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
TANK MANIFOLD (A55745)
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A56138)
2016 INTERNATIONAL...
