R4 Tires in snow
   / R4 Tires in snow #1
haveissues
New York
Kubota b2620
So I have to say the R4 tires on my kubota b2620 worked way better than I expected. I have a very steep driveway and had no issue getting up and moving around. A couple of times my front wheel went off the side of the driveway while piling up snow. After locking the diff I was able to back out uphill with no issue. I thought I would need chains but I don't think I will bother now. :cool2:
   / R4 Tires in snow
I'm cheap so I used windshield washer fluid but I could put 10 more gallons or so in each tire still.
   / R4 Tires in snow #4
I run R4's w/no chains but loaded rear tires,you might see change in traction when snow not dry.
   / R4 Tires in snow #5
I agree, I had R4's on my Kioti CK25 and in slushy stuff, it would slide all over the place on the hills. Chains fixed that right up. My :2cents:
   / R4 Tires in snow #6
My tractor with R-4's and loaded rear tires is near useless without chains when plowing with a 9' front blade.
   / R4 Tires in snow #7
I'll second that. I have v-bar 2 link chains on my front tires of the L3400 and I was fighting to keep my loaded rears behind me when I was pushing across the slope on some clean up passes. I was pushing an 8' meyers truck plow mounted to a homemade subframe.
   / R4 Tires in snow #8
i'm with you so far. have the same setup and not even a bit of slippage. of course i have it in 4 wheel drive, but again, no problems.
   / R4 Tires in snow #9
Ive had good luck with R-4s and Duo grip tire chains.
   / R4 Tires in snow #10
I also have R4s with steep gravel driveway, they work okay in snow but had to get chains for ice. Chains make a BIG difference.
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
SCAN TO RECEIVE TEXT UPDATES (A52706)
SCAN TO RECEIVE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55302)
2003 International...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
