KOYKER Loader won't lift
   / KOYKER Loader won't lift #1
dogbrdr1
Neosho, MO
2003 Mahindra 2310
I have a YTO 40HP tractor with about 85 hours. It has a fairly new Koyker Loader on it. All of a sudden one day it won't lift...IDK??? I opened all the lines one at a time and worked the controls and fluid squirted out so I can't figure out why it won't lift.......
   / KOYKER Loader won't lift #2
check ALL qd fittings. one may be loose.
if nothing, and your pump is making 'FLOW' out of the pressure port. get a t and put a pressure gauge in line.
post back
post back
I have checked the fittings. How much pressure should it have?
   / KOYKER Loader won't lift #4
most ag setups are around 2500 psi at relief. or thereabouts.... loader valve may be set uder master relief on tractor pump. depends on setup.
   / KOYKER Loader won't lift #5
Is your three point hitch lifting? Put something heavy on it. If it lifts your pump has at least some pressure.
   / KOYKER Loader won't lift #6
Pressure is determined by load.
If you have a hyd gage, plug it into one of the loader lines and activate the lever momentarily.
The gage will show relief pressure.
Check your manual for relief pressure.
KUBOTA Z231 KW ZERO TURN MOWER (A51247)
KUBOTA Z231 KW...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
