buckeyefarmer
Super Star Member
Did it come with incandescent bulbs?
No, but specifically states use incandescent or CFL, and specifically states do not use LED. Fixture came with garage door opener, uses two 100W max.
Maybe they've had customer complaints because RFI from the LED's - mounted right on the receiver - blocked the signal from the remote.No, but specifically states use incandescent or CFL, and specifically states do not use LED. Fixture came with garage door opener, uses two 100W max.
Last I heard, CFL's weren't supposed to be in cans. We did have 2 in the cans on our ceiling fan lights that got hot. Bases were brown & burned looking when I pulled them out after they quit--that's when I heard I wasn't supposed to put them there.
When you expect instant full output CFLs come up short. But if used several minutes or longer they compare quite well at 1/4 the power. I use about 600W of CFLs to well light my 1500sqft basement.I put these 100W equivalent bulbs in the garage and I need a flashlight to see.
if any business had invented this product with mercury in it the Feds would have sued them back to the stone age.
I find you need to change the batts to US alkalines right away. Batts included will corrode it up quick.They don't last as long as a disposable lighter
:confused2: LEDs brighten faster than incandescents.I bought LED from Costco and use them...
The only complaint is they take awhile to come up to full brightness...
City just changed out all the street lights... 420,000 people live here and they said it is very cost effective.
We also pay as much as 32 cents per Kw
This is the 4th time in my lifetime they have changed out the lamps...
It went from very bright to not so bright and then to energy saver "Orange" and now to LED.
The light pattern is very different... mostly the light is focused along the street and not people's windows.
The exception is the pole at the end of the court... it illuminates both the yards to the left and right like never before.
