MotorSeven
Elite Member
Here are some pictures after paint and flooring:
Rich, it's glue down. It has a glue strip extending out an inch on two sides, then a matching recess on the other two sides. The instructions say you have about 15 min to change your mind once it's together. I had to pull a few apart after a few seconds, the stuff bonds really well.
This is the one I went with, watch the video:
TrafficMaster Allure 6 in. x 36 in. Country Pine Resilient Vinyl Plank Flooring (24 sq. ft./Case)-33114 at The Home Depot
I have done a lot of composite laminate flooring, and although it is easy I was dreading doing it by myself because you have to run outside to make a cut every row. Although it's hard on the knees, you don't have to get up at all. I would say it is by far the easiest floor I have ever put down.
