Need Extra Long cat 1 Lift (Draw) Pins
   / Need Extra Long cat 1 Lift (Draw) Pins #1
Beltzington
Appling, Georgia
JD 3720
Recently bought an MX6 (RC) at an auction and did not notice it had cat 2 pins. I have a cat 1 3-point and have been unable to find off-shelf replacement pins. 3.5" of length on the thread side "might" work, 4"+ would be better but after much internet searching, nothing. Link Pins listed as Extra-long are long on the link side which I do not need. OEM sells them but I would rather not pay $40/pin. Any resources or suggestions I could try?
   / Need Extra Long cat 1 Lift (Draw) Pins #2
Try Tractor Supply if you have one near, or Tractor Supply .com :)
   / Need Extra Long cat 1 Lift (Draw) Pins #4
Any pics of the cutter? I am unfamiliar with the mx6 but it seems odd that you need 4" of thread. Even for cat II, 4" is alot of threads.
I have taken cat II pins and turned them down to 7/8" on a lathe before. With a lathe, and the old pins, it would only take ~5 minutes to peel the 1/4" difference off. Do you know anyone with a lathe? If you were near me, I would certainly do it for under $40.
   / Need Extra Long cat 1 Lift (Draw) Pins #5
You can always put some cat 2 bushings on your tractors lift arms.
JD MX6 is their medium duty 72" RC, it typically comes with Cat 1 pins but a Cat 2 option is available which adds another brace and heavier pins. Because of the added brace the Cat 2 Pine is too long to work even after being turned.
Changing lifts to Cat 2 is a good idea except I have 3 other Cat 1 attachments.
   / Need Extra Long cat 1 Lift (Draw) Pins #8
i buy mine at a dealer that sells farm tractors.
   / Need Extra Long cat 1 Lift (Draw) Pins #9
I am not positive, but I think you can and should remove the extra brace.
I am assuming the "extra" brace is the outside piece. I think it is there to be a spacer mostly, from the looks, cause cat II usually needs that extra spacing. structurally, that brace dont look to be doing a whole lot.
Yes - the brace is part of the cat 2 option to increase the width between the lift arms and is removed. The thickness of the remaining square tubing and braces is just over 3.25".
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2013 CAT 246C (A47477)
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
