Need Extra Long cat 1 Lift (Draw) Pins
   / Need Extra Long cat 1 Lift (Draw) Pins #11
the difference the spacer does is to take the 26" Cat one spacing to a Cat two spacing of approx. 32". Remove the spacers and you should be back at 26".
   / Need Extra Long cat 1 Lift (Draw) Pins #12
That tubing sure didn't look that thick.
I am afraid I can help. Other than just. browsing the web hoping to find something.
   / Need Extra Long cat 1 Lift (Draw) Pins #13
I'm not sure if you are still looking for advice but like was mentioned earlier you could convert your hitch to cat 2 for the mower and use bushings on your cat 1 implements to use them on your new cat 2 hitch.
I am using cat 1 implements on a cat 3 hitch and it's worked out great, I ended up spot welding the bushings on the pins and makes hooking up easy.
   / Need Extra Long cat 1 Lift (Draw) Pins #14
Just get the short ones and put the nut inside of the tube that should make it reach.
Edit:
Nope guess that won't work either never saw the brace on the other side! How about putting the nut on the inside, and then get a bolt and nut for the other side and put that nut inside also. or Can you weld? Weld a longer threaded end on, is the only other thing I can think of.
2016 CLUB CAR CARRYALL 550 GAS GOLF CART (A54756)
2016 CLUB CAR...
New Idea 6254 Round Baler (A50775)
New Idea 6254...
UNUSED TELESCOPIC LADDER - 3.2M (A54757)
UNUSED TELESCOPIC...
John Dozer JD650 (A51691)
John Dozer JD650...
Case 1845C (A47477)
Case 1845C (A47477)
