Another which Mott is this thread
   / Another which Mott is this thread #1
Locoweed
West Tx.
Kubota B2620
This is a 5 footer I found on CL. If it takes different parts from the standard model 60, I would appreciate any & all info. Does anyone know how much this weighs? It appears to be in fair shape, cleaning, painting & a new set of flails at the least will make this a nice winter project.
Well, the math says 700#, but it looks like you have quarter inch side frames vs 3/16 on mine. I imagine there are a few other differences, rough cut vs fine cut etc. Somewhere around 650# would be my guess. It will be interesting to see how my little B2620 handles the weight.
Yep, I have skimmed most of that thread & will take the time to peruse it a bit more closely this weekend. We are due some bad weather that will probably keep me in close proximity to the wood stove.
Thanks
   / Another which Mott is this thread #4
Thanks
Your'e welcome, glad to be able to help.
Let us know how it works for you. :thumbsup:
Got a set of blades for it & did a small amount of cutting today. It seems to work ok.
Can someone clear up something for me?
In the manual I found it talks about independently floating lift arms
I believe I have a set of the chains, but cannot figure out how I can use them. Anyone with pics showing them in use?
Thanks
   / Another which Mott is this thread #6
You would replace the lift arm links, with chains, so the mower will raise the individual lift arm on uneven ground.
In this drawing they are "lift arm leveling assembly"
Post a picture of your 3 point hitch if you have any questions.
I was suffering from tunnel vision I guess. Looked over the situation this morning & it became obvious. I will have to modify the chains to make them fit my tractor.
Thanks for the pic.
Time for a update. The weather wasn't too bad today, so I got some paint squirted on it.
   / Another which Mott is this thread #9
An orange Mott.:eek: It looks like a 60" super heavy duty fine cut. The heavy duty model uses a 2" pipe cutter shaft and SHD uses a 4" pipe cutter shaft. Good Find.:thumbsup: You don't need to worry too much about the chains unless you have a lot of undulations or hills where you're mowing. Set the cutting height with the rear roller.
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
Blue Diamond 103709 (A53317)
Blue Diamond...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
1000000 (A47477)
1000000 (A47477)
