SCUT with cab for front mounted snowblowing
   / SCUT with cab for front mounted snowblowing #21
I may be asking too much from one tractor, perhaps a separate mower and cab'd tractor would be better for total needs/wants.
That was our conclusion, and so we did ijust that.
   / SCUT with cab for front mounted snowblowing #22
Kioti does make a 25 or so HP tractor with an optional factory cab. I dont remember the model, but they had one with a front pto mounted snowblower on my local tractor lot last year. The cab is heated, but no a/c.
I have a Kioti CK27HST with a factory cab and a front mount snow blower. It has heat only. When I first start to blow snow the windows will fog up a little, but it quickly goes away. I, too can blow snow in a T-shirt once the heat is up.
   / SCUT with cab for front mounted snowblowing #23
thats the one i was thinking about. thanks
Thank You, I will look into when I am next at the dealer.
   / SCUT with cab for front mounted snowblowing #25
I have the B7610 no blower but have the Curtis cab with heat,, It used to fog up on me but this year I installed a fan in the top right rear corner,, Wow it works great...
   / SCUT with cab for front mounted snowblowing #26
I had a Curtis cab on my New Holland TC40D and later on my TC40DA. The first time installation was probably 8 hours total but I added two lights on the front and back. Wiring for the lights, windshield wiper, defogger fan and the fan for the heater took a few hours. Plumbing for the heater also took some time the first time. I took it off the following spring and it took about an hour. Reinstalling the following fall was about a two hour job as everything was in place. I had the cab for 5 years before I traded for the John Deere 4720 with factory cab. I never minded the on and off procedure with the Curtis cab. I was a mid-november procedure and was all of the process of getting ready for winter.
2011 Genie Z80 Man Lift (A54865)
2011 Genie Z80 Man...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
