driveway protection from blade?
   / driveway protection from blade? #1
bucktaker
Sw Ohio
Kubota L5740
Hello
With the recent heavy wet snow my blower (woods 6215 mower with grasshopper blower) was useless as it clogged no matter what I did. I got out the L5740 Kubota and made short work of it.
I dislike using the tractor cause I always leave scrap marks on the blacktop coating. What have others done to prevent this? Thinking of maybe a hardwood edge attached to my bucket?
   / driveway protection from blade? #2
Almost anything attached to the bucket will prevent marks on your driveway. Usually, the issue is how it gets attached and if you have to drill through bucket. There's a sticky thread at the top of this forum of a commercial solution and there are plenty of threads about other solutions, from wooden planks to plastic pipe.
   / driveway protection from blade? #3
I just use the blower or bucket edges in contact with the blacktop. Marks don't bother me.
   / driveway protection from blade? #4
How about a thick rubber blade in place of your cutting edge
   / driveway protection from blade? #5
Piece of conveyor belt bolted to the edge works great. You can find it at Tractor Supply or if you know anyone at an old mine or manufactureing facility you maybe able to get a piece from an old belt they are pitching out.
   / driveway protection from blade? #6
I seen somewhere on the internet they had a hard plastic that attached to the buckets cutting edge. It was yellow with like 5 screw bolts the stuck up.
   / driveway protection from blade? #7
There's a sticky thread at the top of this forum.
   / driveway protection from blade? #9
   / driveway protection from blade? #10
Here is what I use. It came off a county highways plow.
2002 Mercury 8 HP Tiller Outboard Motor (A50325)
2002 Mercury 8 HP...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52748)
2018 John Deere...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
