CobyRupert
Super Member
Thanks, some good advice here.
Is Kerosene the same as No. 1 diesel? Same as No. 1 fuel oil?
Ran into a similar situation with the BX2660 last week when it was in the single digits. Put it in the unheated shop with a 300W floodlight pointing up at the main filter. Poured a dose of PS911 in the tank, let it sit overnight, the fired it up in the morning.
Finished filling it from the big tank (which has white power service in it) and it was fine.
Aaron Z
CobyRupert,
Kerosene, No. 1 Diesel (ASTM D975), No. 1 Fuel Oil, and Kerojet A are similar, but not the same. The distillation curves & additives are all different. Don't cut No. 2 Diesel Fuel with kerosene, and always add supplemental additive. You need lubricity all the time, and this time of year anti-gel. I also recommend cetane improver as most of our engines are indirect-injected and need the help. Esp. in cold ambients.
Just run white bottle Power Service and don't worry about it.Can you cut it with kerosene if you also add the anti-gel with lubricate? Is that enough lubricant, given that it's in the No.2 and you're only cutting it about 30%?
Seems like there's a lot of stories on here about people who do. (Though, I guess you don't know how much the No.2 was already cut at the station, but I know it's not good for -20F.)
The problem is, I don't know where to get small quantities of No. 1, but kerosene is available.
