White Smoke
   / White Smoke #1
willhoff
new concord, ohio
john deere
I have a JD diesel engine that blows white smoke going down a hill. When I start back up the hill it clears up and runs fine. The engine does not use any oil. What should I look for??
   / White Smoke #2
water in the fuel tank...
   / White Smoke #4
I always attributed white smoke to unburned fuel to start with. It can be other things but unburned fuel is most common I think. You will see it when cranking before it starts. If you had white smoke all the time and it was hard to start I would suspect a compression problem But just down hill I don't know weather that is a worry or not.
   / White Smoke #7
Is the coolant level steady?
   / White Smoke
That was one of my thoughts.. I drained the fuel filter several times >> that didn't help? I put a new filter on the tractor >> that didn't help? I did not see any water in the fuel when I opened the drain.
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52128)
2019 Tico Yard...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2015 F-550 Bucket Truck Gas Engine (A52128)
2015 F-550 Bucket...
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
