White Smoke
   / White Smoke #1
willhoff
new concord, ohio
john deere
I have a JD diesel engine that blows white smoke going down a hill. When I start back up the hill it clears up and runs fine. The engine does not use any oil. What should I look for??
   / White Smoke #2
water in the fuel tank...
   / White Smoke #4
I always attributed white smoke to unburned fuel to start with. It can be other things but unburned fuel is most common I think. You will see it when cranking before it starts. If you had white smoke all the time and it was hard to start I would suspect a compression problem But just down hill I don't know weather that is a worry or not.
   / White Smoke #7
Is the coolant level steady?
   / White Smoke
That was one of my thoughts.. I drained the fuel filter several times >> that didn't help? I put a new filter on the tractor >> that didn't help? I did not see any water in the fuel when I opened the drain.
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52128)
2016 KBH...
