White Smoke
   / White Smoke
I never see any smoke when this tractor starts. Just touch the key and it is running! This morning when I was feeding cows, I could hear a little miss. I was starting to question the injectors?
   / White Smoke #13
Its probably the tank. Water settled into a corner or some BS like that. Diesel is a light oil so water sinks to the bottom and usually pools. Even a dime sized drop can give you fits.
Best thing is to remove the tank if possible, dump and clean it, reinstall. Draining is not usually enough. You could also vacuum it.
ps.... its good to be the pope.
   / White Smoke #15
I wish I was the pope >> free wine!!
Now that's thinking...!
try parking on a down hill slope and let the tractor sit...then check the fuel supply chain starting at the tank...
   / White Smoke #16
What JD is it?
Many are made by others.
First check the valve clearance. Then pull the injectors and reattach them outside the engine and spin the engine at full throttle. this is not to start the tractor but to see the injector spray pattern. third what type of air filtering system does it have? Clean the oil bath or replace the paper filter if it is dirty.
   / White Smoke #17
Depending on the actual manufacturer I would probably remove the injectors and fill the cylinders with DOT 4 brake fluid acetone and ATF and check and refill daily until the fluid easliy and quickly drains past the rings. Plan on thisbeing a 2 week task and use several quarts of brake fluid and atf. This is to remove any deposits from the rings before they stick or break.
First check valves then injectors then air supply and last decarbon the rings
   / White Smoke
I will pull the tank and empty it. That sounds allot easier then pulling the head. Thank You..
2022 Bobcat E88 Excavator (RIDE AND DRIVE) (A50774)
2022 Bobcat E88...
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2015 FREIGHTLINER...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
