Kubota 40 series, A simple seat squeak fix with option disabled
   / Kubota 40 series, A simple seat squeak fix with option disabled #11
Someday I will do that also, but for now, I'm happier
I'm sure it is an improvement and the Grammar is way expensive, I had to really think about it long and hard.
   / Kubota 40 series, A simple seat squeak fix with option disabled #13
And you should be with that beautiful tractor :thumbsup:
Agreed, very nice machine indeed and I'm sure there will be more to come.
   / Kubota 40 series, A simple seat squeak fix with option disabled #14
BUMP. The original photos are gone. Does anyone know what he was showing? Are the 4 nuts the ones on the top side of the plate, for the 4 pivot pins? I am so desperate to get rid of the noise I might be willing give up the swivel. Sprayed fluid film on every moving joint I could see, only made a minor difference.
   / Kubota 40 series, A simple seat squeak fix with option disabled #15
My swivel seat squeaked and it was coming from the unlock lever for the swivel. Put a bit of bearing grease on the sides of the lever where it engages the seat and now it is quite. Sorry I don't have any pictures to clarify where I'm talking about.
   / Kubota 40 series, A simple seat squeak fix with option disabled #16
Thanks moship, I know where you're talking about, I'll try that. Yesterday I tried the fix that I think Waxman was talking about, it didn't really make much, if any, difference on mine. And I do use the seat rotation, so I'll have to put those spacers back in. It is crazy how badly this thing squeaks, every little bump.
   / Kubota 40 series, A simple seat squeak fix with option disabled #17
No, not the rotation lever. Thinking I'll have to pull the seat out and disassemble.
   / Kubota 40 series, A simple seat squeak fix with option disabled #18
I've taken care of most of the seat noise, but it turns out that was only about half of the noise. Seems like there is also considerable squeak coming from the two front cab mounts, and a tiny amount from the rear mounts. Is this normal for the Grand L Cabs?
2020 INTERNATIONAL RH613 (A58214)
2020 INTERNATIONAL...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
2016 Chevrolet Express Shuttle Bus (A56858)
2016 Chevrolet...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2392 (A58376)
2392 (A58376)
1770 (A58375)
1770 (A58375)
