Massey Ferguson 261 perkins 4 cyl diesel
   / Massey Ferguson 261 perkins 4 cyl diesel
but this is a perkins diesel no spark plug holes?
   / Massey Ferguson 261 perkins 4 cyl diesel #12
Sorry, I meant to say "spark plug holes, or injector holes". They work on either gas or diesel engines, but for a diesel you need to make sure the gauge will go high enough. As I recall, 400psi would be enough, but even Harbor Freight sells one that's cheap, and goes to 1,000psi. The only thing I'd research is what thread they use on the injector holes, and compare that with what the kits offer.
12 Piece Diesel Engine Compression Tester
   / Massey Ferguson 261 perkins 4 cyl diesel #13
I dont think that compression tester you listed will not work on his engine.
I believe that his injectors are the type that are held down by 2 nuts on the studs on each side of the injector base.
If thats the case, he will need an adapter that locates on the 2 studs, tighten them down, and then screw the tip of the tester on down into the hole. That adaptor is in the 14pc set from Harbor Freight but its like 180 bucks.
Automan does you injectors have the two studs holding them down and then your fuel lines screw into you injectors at a 90 degree angle from the injectors? They will look something like this one in the picture on the page listed.
http://www.mdm-parts.com/Injector-168-4236_1
yes that is how mine is.
   / Massey Ferguson 261 perkins 4 cyl diesel #15
I did a google search for antique tractor clubs in and around Houston and the Bluebonnet Antique Tractor Club popped up with a nice website. I would suggest that you seek these guys out and perhaps meet a few of them, or even join the club, and see if a member would help you out with a compression test.
The list all types of manufactures in their club so your Massey will not be an issue. Here is the link to their website
About Us
Chances are that someone in the club has rebuilt that very motor before and can assist you in more than one way.
   / Massey Ferguson 261 perkins 4 cyl diesel #16
Injector 168 4.236, 62,48 €, MDM parts - MDM Handelsgesellschaft
I should have been more clear....I was just using that tester as a geneic example. That's why I mentioned researching the exact injector, to be certain.
Thanks for ya'lls help. I appreciate it. Brian
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
PAIR OF UNUSED 60" HANG ON FORKS (A54757)
PAIR OF UNUSED 60"...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
