Blue Birds
   / Blue Birds #21
I live in Michigan and oversee the maintenance of about 100 bluebird nest boxes. You probably have tree swallows nesting in the bluebird boxes, not martins, which nest in a single colony. To get around this, we place nest boxes in pairs as they will nest next to another species, but not their own kind.
Both robins and bluebirds will overwinter if the temperatures are not too cold. They feed on dried berries left in the trees.
We have blue birds over wintering this year located southern WI. Just acouple of days ago when the temp was -18F daytime. They were sitting at our heated bird bath.
Curious as to above qoute as to putting up "pairs" of blue bird houses. Would these be mounted on the same post with openings opposite directions from each other or short distance (i.e. 2-3 ft) from one another or? We have the tree swallow / blue bird dilema. Sparrows will take over a blue bird nest box with no mercy. Double boxes sound as a small price to pay to get rid of the pesky and very smart sparrows.
Have a great day!
   / Blue Birds #22
We have never seen tree swallows destroy a bluebird nest.
Wrens will.
Coons will.
English sparrows will.
Snakes will.
Once a nest is destroyed swallows or whoever will try build on the old bluebird nest.
Unless you saw it with your own eyes how do you know who did the destruction?
Seeing swallows going in after the fact is no proof.
Another reason for the thick door hole is to keep coons from reaching in to the babies.
My experience, too, over 15 years of monitoring bluebird boxes.
   / Blue Birds #23
Is it normal to have Blue Birds this far North in January?? I'm 6 miles South of the Missouri/Iowa border in Northwestern Missouri.
I'd say it's unusual. Even with feeders, don't ever recall seeing a Blue Bird around here in Winter. In Summer they are rare and we are roughly the same latitude as you.
   / Blue Birds #24
I had Purple Martins for several years. Until the B-Martin showed up. Very aggressive and territorial bird. About 2/3 size of Purple Martin, medium grey color with white chest. About 50 of them moved in last Spring, ran Bluebirds out of their nests. Completely ran off my Purple Martins. As I said, I had to close all my nests. I have 25 nests scattered about my yard and buildings. They would have nested in all of them if I hadn't shut them. I waited until they moved on, then opened up two Bluebird nests and got two hatches. I'm anxious to see if the B-Martins come back this year. If they do I guess I'm out of the nesting business until they give up on me. Really aggravates me.
I hate the B-Martin. They will crowd the blue birds and other birds out. They will also empty bird feeders of food.
   / Blue Birds #25
We have a blue bird trail with around a dozen boxes presently. I drew up some plans for a really nice bluebird house that has a thick opening and metal washer to keep the birds from pecking the hole larger in case you're interested in building some of your own.
The plans are down at the bottom of the page.
page5
   / Blue Birds #26
I've nested Blue Birds around my property for 30 years. Last Summer was my lowest production in several years because B-Martins took over most nests and I had to block the nests. But still had several hatches of Blue Birds.
Anyway, I digress.... Normally in the late Fall Blue Birds will gather at our property, dozens of them. I always assumed they were gathering where they were born or had hatched chicks for the migratory flight South??
Usually I don't see Blue Birds again until warm weather. This morning there were three sitting on the power line, their favorite spot to hunt for food. I don't recall ever seeing them here this time of year. Maybe all the weird weather and wind we've had lately has them confused??
Richard,
As I cautioned you on your other thread, your entire bucket is exposed, to the WWW. the way you are showing your pictures.
IE. Thanksgiving 2011 and the entire string of folders and photos down the left column.
I just looked at that one to give you an example. Stacked Cans.
If you want to get some fun shots of your bluebirds put a small birdbath below the wire where they come down to feed. They love a late afternoon bath. We have 5-6 in there at once. Here are a couple. This bath is right below our wire.
   / Blue Birds #27
These are tree swallows.
They look just like purple martins but are a little smaller and are white underneath. In flight their back and wings will reflect some purple color.
Purple Martins are dark all over.
Barn Swallows are Brown colored on their chest and dark steel blue on their back.
All of these swallows and martins are shiny in the sun.
   / Blue Birds #28
Bluebirds are here year-round in my part of Virginia. We hatched several dozen at our old property, and I plan to put up a couple houses at our new place in the next couple weeks so they have time to shop around in spring.
We had raccoon and snake problems early on until I redesigned our houses and poles, but the biggest pest over the years have been sparrows. They are tenacious. I finally figured out how to trap them in the bluebird houses when they tried to take over (flap over the door I could close from a distance with a string), and would relocate them far away. Apparently it's legal to kill sparrows since they are non native, but I never took it that far.
I've always understood that bluebird houses should be mounted on poles, and no closer than about 50 feet from each other. I have taken to mounting stove pipe on top of poles to block snakes, and use thick wood on the front of the house so raccoons can't reach in. At our new place, it would be convenient to mount houses to trees, but I can't see a way to make that snake proof -- anyone know any tricks? Will bluebirds even nest in a house attached to a tree?
   / Blue Birds #29
If you have and enjoy blue birds...look for special meal worm suet and put it out...
dried meal worms are also good but the blue birds don't take to them until they get wet and soft...
   / Blue Birds #30
Blue birds like to be in more open areas rather than on trees.
We put ours along fence lines, on wooden posts around the garden and orchard as well as the 5 power line poles on our property, with permission.
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
